Compact tractor with highest road speed ?
   / Compact tractor with highest road speed ? #1
wbyman
Member
I own a NH tc30 with 30 hp and want to upgrade to something in the 35 to 40 hp range. I have about 10 miles between food plots and I don't want to buy a trailer. Which compact tractor has the highest top speed ? It woud be nice to find one that would go 20 plus mph. Thanks !
   / Compact tractor with highest road speed ? #2
I'm not aware of any late model compact tractors that have 20 + MPH capabilities. I think some of the older Minneapolis Molines would do that. The Ford 8N or 9N with a Sherman overdrive would do better than 20 MPH. We called the fords with the overdrive "Amish Ferarris". Either one of the above mentioned machines would be a considerable downgrade from present.
A good tow bar might do the job after verifying no damage to your drive train with towing. If HST, tow bar is out. I sure wouldn't want to go fast with a tow bar, but I would think 20+ would be achievable.
   / Compact tractor with highest road speed ? #3
i would wont to tow any tractor down the road behind a pick to much to can go wrong that could cost more to fix than a trailer would cost
   / Compact tractor with highest road speed ? #4
You will wear your tires out for no good reason! Get a trailer.
   / Compact tractor with highest road speed ? #5
Tractors are just NOT built for speed... handling and brakes are crappy enough at the 13mph... buy or rent a trailer.
   / Compact tractor with highest road speed ? #6
When I was growing up on the farm, we often had no truck or trailer to haul a broken tractor, so towing was the only way to get them to the shop. I sure won't recommend it and won't do it now.
   / Compact tractor with highest road speed ? #7
Just get a trailer. Even getting a cheep trailer would be better than driving it...
   / Compact tractor with highest road speed ? #8
I use my NH tC- 29 to bush hog on my farm and it is a 5 mile ride ..I average 12 to 13 MPH and it takes me 20 minutes. I will not buy a trailer since it would take me 20 minutes by the time I hooked the trailer up to my truck and chianed it down..by that time I would already be at the farm and working...I don't like the 20 min. ride but it beats wasting the money and time with a trailer ..JMO
   / Compact tractor with highest road speed ? #9
Yea, I drove mine 5 miles instead of putting it on a trailer. It was fine except for 0.2 miles, I worried about dieing in a wreck... too many trucks on that section. If it was all back roads, that would be different.
A farmer got hit by a car with a trailer... car came up on the tractor too fast and he didn't think about the extra weight of the trailer... the farmer was fine, he had a big sub-soiler on the back which destroyed the drivers radiator... Could have easily been a death.
   / Compact tractor with highest road speed ? #10
The JD 3x20 series with R1 - AGs or large R4 or R3 Turf seems to have a top speed of 18 - 19 mph.
METAL FILING CABINET (A53843)
METAL FILING...
SKID STEER SCARIFIER ATTACHMENT (A53843)
SKID STEER...
SDLANCH TRACKED MINI LOADER (A53843)
SDLANCH TRACKED...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
CASE 580 (A47477)
CASE 580 (A47477)
Utility Trailer (A52377)
Utility Trailer...
