Help with electrical connection for 12 v winch
   / Help with electrical connection for 12 v winch #12
As others have pointed out, Anderson Connectors are what you probably want. Find out what amperage your winch draws on say a 500 lb load (or whatever load you are comfortable with) and size the electrical cable and connectors for that load. Rotating a chute should take next to nothing for load if everything is right with the world, eh? :)
   / Help with electrical connection for 12 v winch #15
A winch only has tension in one direction normally. So what kind of contraption is necessary to create tension in both directions?
   / Help with electrical connection for 12 v winch #16
A loop of cable wrapped around the chute and back onto the winch.
Aaron Z
   / Help with electrical connection for 12 v winch #17
The small size Anderson Connectors will work fine. I use them on small winches all the time. The actual contacts should be coated with die-electric grease to prevent corrosion though. For your use, you will only be applying current for a few seconds to swing the chute, but when the chute gets iced up there will be a good load. Go with at #8 superflexible wire (or double up #10's). Future shop should have #10 speaker wire (thats what I've been using on ATV winches).
Just run the winch controller (I'm assuming that you are using a winch relay) into the cab when you need it.
Make sure that you solder the Anderson lugs and don't just try to crimp them.
If you are using the pushbutton controller that comes with some of the small winches you can just extend the wires as needed but I've had about 5 give up the ghost when friends have used them on ATV's. You might get lucky because of the short duration of your loads.
If you are going to fuse the feed, use a 100amp fuse. Normally we don't fuse a winch but are really careful when we route the wire to prevent fraying. (PM me for details)
   / Help with electrical connection for 12 v winch #18
You have to be careful not to run to far in either direction then, yes?
   / Help with electrical connection for 12 v winch #20
My last 2 winches, a Warn 3000 and now a 4000, both had #6 cable running from battery to solenoid and solenoid to winch. You can go lighter for this light load, but it is never good for the motor if they are too light.
But, if you are saying it's already a lighter gauge then go for it.
Remember, when everything is frozen and you hit the button, the load is going to skyrocket.
2000 Ford Expedition SUV (A51694)
2000 Ford...
2014 Ag Spray Schaben Sidedresser (A53473)
2014 Ag Spray...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 CuYd Refuse Garbage Truck (A51692)
2007 Freightliner...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2018 Kia Soul Hatchback (A51694)
2018 Kia Soul...
