Time to change coolant and flush a 186d
   / Time to change coolant and flush a 186d #1
Pete Judd
The Thin Gravy Ranch in The wet PNW
Yanmar 186d, JD 314
Any tricks to this, as I will be doing this this week, went to wally world and got the coolant today, but worried that I have hard water and after the final flush will be using distilled water mixed 50/50 with the antifreze.
   / Time to change coolant and flush a 186d #2
O buy pre-mixed.
   / Time to change coolant and flush a 186d #3
I haven't done my YM186D but the YM240 was incredibly simple.
All I can suggest is remove all hoses connectors and reverse flush everything extensively.
There may be a small hose between the bottom of the radiator and the bottom of the block. If so, that can help reverse flush the block.
I like the idea of distilled or de-ionized water. I use that too.
I did not buy the premix as I have the boat to do as well, but will put it in a cup at a time, one cup of coolant, then one cup of water until it is full, thanks for the help
   / Time to change coolant and flush a 186d #5
For a reverse flush just remove the tstat and disconnect upper hose at the radiator. Shove a garden hose into the upper hose, seal with shop rags,turn on the water and let the coolant and crud run out the rad top until water runs clear.
   / Time to change coolant and flush a 186d #6
An easier way i do it is to have an empty collant jug with the clear sight mark with gallons or quarts marked on it. Will fill it to 1/2 gallon with antifreeze then to the 1 gallon mark with my water. You have a perfect 50/50 mix for half the price of the shelf stuff. You can even mix 75/25 or 40 /60 but the later will be a little guess, but you will be close enough for radiator fluid, your not mixing 2 stroke fuel.
   / Time to change coolant and flush a 186d #7
I don't blend the water/antifreeze in advance because too many times the coolant capacity has turned out to be less than I planned for.
   / Time to change coolant and flush a 186d #8
Back flushing is good. I'd do it with tap water and wouldn't use any of the acidic flushing compounds in a system that is cooling properly. No need to over-thin an already thin radiator shell.
From what I understand, the water pump on the YM186D will mix the water and antifreeze for you. So there's no real need to premix the water and antifreeze on the models that have a waterpump, but it can't hurt. For the tractors with the thermosiphon type of cooling system premixing is necessary because the two fluids have slightly different density and will stay separate for a long time.
I like to mix with distilled water because I know there's no hard water sufates and carbonates in it that will plate out on the metal tubes of the radiator and reduce the cooling efficiency. I'm not yet convinced on the whether de-ionized water has any advantage or not.
rScotty
   / Time to change coolant and flush a 186d #9
I would think the mix ratio would depend on where you live. I don't think 25% would be enough protection if the temp gets down near zero. I run near pure antifreeze in the car and truck.
   / Time to change coolant and flush a 186d #10
Even 50/50 protects well below what anyone on the east coast will ever see.
Forklift (A59228)
Forklift (A59228)
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
