rjkobbeman
arrabil,
Are you trying to say that changing leverage does not change the force on something?
1) WELD a 550lb object to the lower hitch arms. Put it's CoG 24" behind the ball eyes.
2) WELD an 1191lb object to the lower hitch arms. Put it's CoG even with the ball eyes.
Do NOT attach the toplink for either.
Tell me, will the MF GC2400 lift these loads to its maximum rockshaft height?
Are you saying in a true //ogram I could place 550lbs a mile behind the tractor and lift it to max capacity?1. You do/did agree that in a TRUE //ogram, it can lift the same MAX capacity at ANY point behind the ball ends correct???
Yes. Obviously so.2. If we welded something on the lower arms as you suggest, you agree that there is a diminishing capacity the farther back the load is placed correct???
We're almost there together this time........... the above is only true in a closed system. On paper or the blackboard. In theory. But if the tractor does not weigh enough up front, the GC2400 cannot follow this formula IN REAL LIFE.This makes the lower link a TRUE lever, with a fixed load, a fixed pivot, and a fixed lift point. The amout it can lift @ 24" is a ratio of how much the lift arm can lift and how far back the lift arm is.
Of course not. I'm trying to say MF isn't talking about physics books; they're talking about real life. So when the OP asks why does the amount at 24" go down so much, its because something else in the tractor prevents it. Otherwise MF wouldn't have made it so. If they could JUST change the geometry of the hitch or toplink you can bet your *** they would have!Are you trying to say that changing leverage does not change the force on something?
Of course not.
Or more likly the MF lawyers want more margin of safety against people doing stupid things and the MF lawyers have more clout at AGCO than the marketing people who want to have number in a brochure as big as possible, regardless of what the machine can or can't do, "safely". There is more in what determins a "safe" rating than a machine's absolute limits.
The lawyers want a "safe" rating against every possible idiot operator and the marketing people want the biggest number they can print on the brochure. Every company has to balance these. Is it not possible that every manufacturer is a little different in this balance?
Tell me, what kind of mechanical leverage does the toplink provide when it is hanging down (before horizontal)?Now are you saying that changing the length and/or position of the toplink does not change the leverage?
See Post 42, 7th paragraphTell me, what kind of mechanical leverage does the toplink provide when it is hanging down (before horizontal)?
See Post 42, 6th paragraphAnd what kind of mechanical leverage does it provide when its furthest point from the tractor is higher than the toplink hole (past horizontal)?
