Chains Which Chains?
   / Which Chains? #1
Grande
Member
Southern Vermont
Kubota L3010HST
Hi all,
I'm about to purchase chains (from tirechain.com) for my L3010 and can't decide between duo-grip or duo-grip with v-bars for added traction. Here in icy southern Vermont it does get a little slimey sometimes. Is simply having chains adequate or is the extra $$$ worth it for v-bars? Whaddaya think?
Thanks,
Jon P
   / Which Chains? #2
Hi,
I don't know actually...
But I do know that you will only do it once! Too expensive to repeat the purchase.
Generally, if I am not sure which way to go in a case like this, I will go the "overkill" route, rather than wish I had later...
In my case I only had 2 link as the option for my B2910. I lusted for a L3010 when I saw the chain options available for that model. /w3tcompact/icons/smile.gif Too late now...I bought the B2910...
Good luck...in your decision. I am sure others here will give you some great specific advice.
Bill in Pgh, PA
   / Which Chains? #3
What is the area u are plowing?
Gravel, asphalt or ????
Gravel or dirt or mud get the best u can(V bars).
Concrete or asphalt go more conservative or
take chance on marking the surface.
   / Which Chains? #4
Grande -- I had ordinary chains on my B1750 which worked just fine...until they ran into that slippery Vermont ice! /w3tcompact/icons/shocked.gif With the L3010 I went with the Norse ice chains and absolutely love them! Under the right conditions Clementine can still slip a bit, but not so much that she gets into trouble. I have the v-bar chains on my ATV, and they do just as well on ice.
Any of the aggressive chains will damage pavement, however.
Pete
   / Which Chains?
Gents,
Thanks for the input. It sounds like V-bars are the right choice for my application. The only pavement I'll ever see will be the in the garage and that I can deal with. The uneven terrain is dirt gravel and often, ice.
Jon
   / Which Chains? #6
I'd also go with the V bars as that is what 's on mine. My tires are much smaller diameter and on hard packed surface the V bars can ride pretty rough.
They will exspecially have an advantage on side slopes.
Egon
   / Which Chains? #7
Grande, I just installed Duo-grip chains from Tirechain.com on Saturday. The chains really fit very well, and the amount of difference in traction was quite amazing. I was able to plow up a hill in 2wd, with the diff. locked, that I was having trouble climbing in 4wd, not plowing. I haven't had a chance to try them on ice, yet, but I would think if you have constant, heavy ice, the v-bars would be the only way to go. Oh, I have an L3010 with R4 tires.
   / Which Chains?
Elmo,
Thanks for the advice. I think I'll do the same. Are you plowing with your tractor? If so, by what method, i.e., bucket, blower, blade, etc.?
Grande
   / Which Chains? #9
Grande, I have a Landpride RBT1584- 7 ft. rear blade that I plow with, I use the ft. bucket to pile snow in tight areas. I'm collecting parts to build a variation of the overpriced Kubota ft. blade setup for future use.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2025 AGT YC-32G (A50123)
2025 AGT YC-32G...
(5) PARTIALLY COMPLETED TRAILER RAMPS (A51247)
(5) PARTIALLY...
FRONTIER SA21G LOT NUMBER 11 (A53084)
FRONTIER SA21G LOT...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
