Can someone tell me where I can order this part online?
   / Can someone tell me where I can order this part online? #1
silverz
manhindra 4005
What is the official name of this part...I search for Sauer Danfoss joystick loader valve and found nothing.
How much does it cost and are there any alternates.
Is this easy to change out? What is involved...thanks.
   / Can someone tell me where I can order this part online? #2
First of all hello and welcome to TBN.
Secondly...
Is this a stock part on a tractor you own or is it an aftermarket loader?
If it is stock, mention what tractor make it is and maybe someone here can give you more info as to where to get the valve.
   / Can someone tell me where I can order this part online? #3
Sauer danfoss is now Danfoss fluid power. Surpluss Center should have a control valve to replace it with. Give them a call. What is wrong with your control valve. They dont go bad verry often.
Bill
It's lifting real slow and one of the nuts fell off.
The tractor is a Manhindra 4005 DI. I bought it with it attached. Not sure if it's stock.
Thanks for any help.
   / Can someone tell me where I can order this part online? #5
My Mahindra 4110 has a Sauer/Danfoss 2 spool valve for my rear remotes and I've asked and searched all over the internet for parts for it for several years with no luck. Mahindra dealers have been no help on it. If you find someone that has parts for them I wish you would let me know !! By the way, most any quality joystick valve can replace yours, it wouldn't necessarily have to be the same brand as what you have now. Surplus Center usually has decent loader valves for a fair price.
   / Can someone tell me where I can order this part online? #6
So is the nut that fell off part of the joystick linkage that works the spools? Lock not from the pressure relief valve? What kind of a nut is it? I suspect that the spool isn't being shifted far enough to get full flow, or less likely (if the nut is from the PRV) your PRV is bypassing oil because it has lost it's adjustment. Hate to see you fork over $$$s for a new valve when all the old valve needs is a minor repair (new nut?). A hydraulic valve should pretty much last the life of a loader. Can you take a picture of where the missing nut goes?
Kim
   / Can someone tell me where I can order this part online? #7
That's a scary answer. I know I could've saved money on a a Mahindra, but didn't do it because of doubts of product support down the road.
Lent it to a relative and he said it fell off and he replaced it. Not sure exactly which one it was. It was under the rubber boot. It's a mystery what really happen but he said he would pay for the fix. Still I don't want to spend too much money on it.
Do you know which Surplus part would be a good replacement and how easy is it to replace?
Kim
   / Can someone tell me where I can order this part online? #9
I think Kim is referring to a valve like this: 9-7401 You may also need the Power Beyond sleeve and some adapters to make it fit.
Skipmarcy
Can you tell me the exact parts you ordered and was it hard to change out.
2011 Ford Ranger Ext. Cab Pickup Truck (A54814)
2011 Ford Ranger...
GREEN CLIMBER P23-80 REMOTE CONTROL SLOPE MOWER (A51406)
GREEN CLIMBER...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
RIGID TOOLBOX (A52472)
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A55787)
2018 JCB 507-42...
