6 Volt Gator, 12 volt TSC spray pump ?
   / 6 Volt Gator, 12 volt TSC spray pump ? #11
:confused2::confused2:
You wanna re-think that statement?
Voltage adds in series;)
Right, so two 12 volt motors in series would run correctly on 24 volts. But we don't have 24 volts, we have 6 volts, so you'd need two 3v motors to operate in series off a 6v battery.
You are right, though, the 12v motors wouldn't operate in parallel on 6v. I was thinking in terms of resistors, keeping a constant current.
   / 6 Volt Gator, 12 volt TSC spray pump ? #12
Yup...My fault for not reading carefully enough. I thought you where referring to the two 6v battery suggestion. Sorry for the confusion:eek::ashamed:
   / 6 Volt Gator, 12 volt TSC spray pump ? #13
I'm still waiting for year and model ... I wonder if its a 6 volt ...
   / 6 Volt Gator, 12 volt TSC spray pump ? #14
No problem, I had myself confused as well. :confused2:
What a DOOFUS I am ! It IS a 12 Volt Gator, very sorry to have wasted everyone's time. I had just taken a quick look at the battery and as little as it was, I had assumed it was 6 volt. I even <thought> I had remembered counting the cells but obviously not. Ready for the home, I guess.
At least I am a happy camper now knowing I don't have to kludge anything together.
I assume I can run the pump off the Gator battery without frying the Gator's recharging circuit, right ? (Sorry, don't have the amperage requirement for the pump, but its just a little one for a 25 gallon sprayer, so I'm guessing an amp or so ?
Bob
   / 6 Volt Gator, 12 volt TSC spray pump ? #16
Bob
Bob,
1. No comment.;)
2. As I recall, my 15 gallon sprayer pump is 2 amp. You shouldn't have any problem -- most of these sprayers are designed for ATVs & UTVs.
Steve
   / 6 Volt Gator, 12 volt TSC spray pump ? #17
Google a boost converter, its roughly a transformer for DC power.
Boost converter - Wikipedia, the free encyclopedia
Thats the theory behind it, with a bit of learning, a trip to radio-shack and some soldering you can build yourself a 12V power source.
Though since P=VI has to be conserved, they're usually suited to low current applications, but i imagine your sprayer pump wouldn't draw TOO much.
   / 6 Volt Gator, 12 volt TSC spray pump ? #18
run the 12 v pump at 6v.
it will pump about half as quick.
My farmer buddie carries a deep cycle 12v onthe front rack of his 4wheeler when he is out spot spraying roundup out of the 15 gal spayer on the back.
charge it with a bat charger once a month or sick a trickle charger on it and plug it in every night.
CATERPILLAR 255 SKID STEER (A52705)
CATERPILLAR 255...
49" X 74" EXPANDED METAL RAMP GATE (A54756)
49" X 74" EXPANDED...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2000 Sterling L9513 Winch Truck (A55218)
2000 Sterling...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
