Bad power steering pump on JD 110TLB.
   / Bad power steering pump on JD 110TLB. #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
I've got about 720 hours on my '08 110TLB, now. There's been a hydraulic pump noise since the tractor was new. I figured it would go away with time (break-in) or new filters and/or hyd oil change-out.
Wrong..
Last night, I was parking the tractor in the garage and with crowded quarters, I locked the FEL in the upright position with the loader cylinder block. With the engine running, I stepped out on the front tire to pull the pin and set the block into position on the hyd cylinder. Standing on the tire, I could feel it jerk and shake occasionally every time the pump would chirp.
My local dealer has been giving me the run around about checking it out - telling me it's "normal". I don't agree - especially since it's getting progressively worse. I can now feel the "pulse" or jerk in the steering wheel whenever the pump makes that chirping noise.
Anybody else have this problem with their tractor? Oh yah, my extended warranty is up in April..
Thanks.
AKfish
   / Bad power steering pump on JD 110TLB. #2
AKfish,
Might be the steering valve instead of the pump, the valve may be loading down the pump causing the noise. Since the pump is essentially two gears there isn't much there to have an intermittent problem. I would definately force the issue with the dealer and the John Deere rep.
   / Bad power steering pump on JD 110TLB. #3
AKfish,
I would agree that it's probably the valve...
Thanks, guys. Your analysis of the problem makes alot more sense... It is intermittent! (Sometimes you're too close to really see!) :confused:
I'll let you know how things turn out.
AKfish
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2022 KMC 21-39-HD LOT NUMBER 197 (A53084)
2022 KMC 21-39-HD...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
