PTO from hydraulic motor
   / PTO from hydraulic motor #1
BrisMatt
Member
Australia
JD 455
I have a JD with auxillery hydraulic ports but without a rear PTO. You can buy a rear PTO kit for this machine but they are no longer sold in Australia and are very expensive. I was thinking about using the machines aux hydraulic port and control valve to run a hydraulic motor that acts as a rear PTO. I have found a few motors at surplus centre that run about 500-600 rpm and provide the adequate torque for my purposes. A link to a motor I had in mind is here.
I was just wondering has anyone attempted this before?
And what coupler is required to fit the pump shaft to a PTO shaft.
Thanks
Matt
   / PTO from hydraulic motor #2
What is the hyd pressure on your pump? Do you have enough hyd flow to run that motor efficiently?
* Dynamic Model Number JPPS-125 H4-K-P
* Displacement 7.7 cu.-in./rev.
* Pressure
1400 PSI Cont.
2000 PSI Int.
* Torque
1354 Cont. in.-lbs.
* Speed
512 RPM Cont.
* Flow
18 GPM Cont.
I believe Surplus Hyd also has the splined coupler
   / PTO from hydraulic motor #3
5 GPM and 7.7 cu in, speed of hyd motor would be about 150 rpm
Looks like I have mixed up my l/min with gpm.
The manual states the charge pump flow is 17.0 L/min (4.5gpm) observed
and the relief valve 1066 psi
its a JD 455. They operate FEL's from these ports usually.
Are these numbers too low to have a rear PTO with an rpm close to 540rpm.
   / PTO from hydraulic motor #6
No - but they are too low to have a rear PTO with any kind of power behind it at that speed.
4.5 GPM of flow run thru a motor with a displacement of 1.92 cu. in. yields 541 rpm
but .... a motor with a displacement of 1.92 cu. in. ..... running at a pressure of 1066 ..... only yields 326 in lbs of torque (which is a little over 27 foot lbs, or almost 37 newton-meters, of torque :()
A larger displacement motor will get you more torque (some) at the same pressure .... but that will result in a slower speed, given your flow (gpm)
I think you really need more flow and pressure to do any substantive work :eek:(as in a rear PTO)
Yes that equates to about 3hp.
I do have a mid PTO which I dont require. It spins at 2000 rpm to run a mower deck. Perhaps a new pump hooked up to that to run a bigger motor. I see surplus centre has PTO motors that require about 20gpm.
   / PTO from hydraulic motor #8
Yup :(
I'm actually looking at doing that very thing myself - to drive a hydraulic pump to power a hydraulic motor to run a snowblower - see my thread here:
Convert Rear PTO Snowblower to Front Hydraulic
It's not that they necessarily require it, it's that they are capable of using it ....
Think about it this way:
A particular flow (in GPM) thru a hydraulic motor (under no load) of a particular displacement will determine the speed of rotation.
When the motor (and as a consequence, the hydraulic pump) encounters resistance, pressure builds - which provides the force/torque/power to accomplish work.
Where can I find a coupling to connect a hydraulic motor to the flywheel of my Yanmar Diesel engine out of my JD 455?
Thanks
Matt
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
NEW Woods 6ft Finish Mower (A53472)
NEW Woods 6ft...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
