Shearing bolt on pto gear box,grasscatcher
   / Shearing bolt on pto gear box,grasscatcher #1
BobG116
Member
North Central Ohio
BX1830
I have a BX1830 tractor with a grass catcher GCK60-BX. After using the grasscatcher for about an hour the bolt breaks and I have to replace it. This has happened quite often. When installing the catcher it is as level as one can get it. When engaging the catcher I do this at about 3/4 throttle. I asked the dealership about this and they say I'm the only who has purchased a grasscatcher and therefore they are not familiar with the problem. Hopefully someone on this site can shed some light as to what is wrong. Thanks for your input.
   / Shearing bolt on pto gear box,grasscatcher #2
Use 1/4 throttle or less when you engage the mower and no more sheared pins- The higher speed is enough to break the shear pinwhich is what it is designed to do for you if you smack an object with a blade.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
Skid steer auger plate (A50322)
Skid steer auger...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
