3-Point Hitch Mahindra 6520 rockshft valve inop.
   / Mahindra 6520 rockshft valve inop. #1
gsmith1986jan
mahindra 6520
My rockshaft valve (3 point hitch) all of a sudden quit working, removed top cover from transmission and found that the valve turned 90 degrees allowing it to slip out from hitting the linkage, tight the valve up and put back together, worked for a few months and quit again. removed all of this again and the problem is else where, changed filters and hyd oils, put back together and worked for a few seconds and quit, my guess its a bad valve or relief stuck open. I have oil going through the 2 bank valves in the back and to the rockshaft valve.
Anyone with this similiar problem ???
   / Mahindra 6520 rockshft valve inop. #2
Not me. I use the 3PH about twice a year. Last time was last month. Nothing wrong then and approaching 600 hours. Main use is the backhoe.
hugs, Brandi
Cat 936 936F 938G Forks (A59213)
Cat 936 936F 938G...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
ALUMINUM STEP LADDER (A52708)
ALUMINUM STEP...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
NEW Landhonor 5400LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
