Would these Hydraulic cyl. work for CAT. 1 top link?
   / Would these Hydraulic cyl. work for CAT. 1 top link? #1
Von
Veteran Member, Advertiser
Western New York
Kubota B2710
I took these hydraulic cyl. off of a Unimog that I am parting out. They were used on a rail unit and would raise and lower the rail wheels. They are 2" diameter with a 10" stroke with a 1" rod with swivel ends that take a 3/4" pin, just like the top link on my Kubota. Would they be too light weight, or would they work for top links? I have four of them and have no use for them. What do you think they are worth? they were working just fine when I took them off last week.
   / Would these Hydraulic cyl. work for CAT. 1 top link? #2
Don't know why they wouldn't work. You'll need the spool of course. If you already have a rear remote then you are pretty much ready to go. It is worth a try at least. The hoses and fittings may set you back a bit.
It should be fine for a Cat 1 top link but something beefier is needed for Cat 2.
You might try posting on the Hydraulic Forum for those experts to give more (and accurate) feedback.
   / Would these Hydraulic cyl. work for CAT. 1 top link? #3
What do you want for 1 or 2 of them?
   / Would these Hydraulic cyl. work for CAT. 1 top link? #4
Another critical dimension to consider is the effective closed length; that is, center to center between each of the 3/4" pin fittings. A little too short isn't a problem with a 10" stroke, cuz I think 8" is pretty standard among Cat 1 toplinks. Too long however, and it's worthless - as a toplink. Measure the closed length of your OE manual toplink as a guide.
//greg//
They measure just under 19" long closed from pin to pin. As for price make me a offer. I would like to get rid of them, as I said I don't need that many!
   / Would these Hydraulic cyl. work for CAT. 1 top link? #6
I have a JD2720, the top link will close to about 17.5"
1831 (A51247)
1831 (A51247)
(2) 275 GALLON POLY TANKS W/ CAGES (A51248)
(2) 275 GALLON...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
2023 UNVERFERTH 632 LOT IDENTIFIER 147 (A53084)
2023 UNVERFERTH...
