Gravely 16G
   / Gravely 16G #1
Giles
Florence Alabama
2009 Kubota B2320---Wheelhorse lawn mower--- Case 480D Backhoe
I just bought a Gravely 16G Lawn Tractor. Absolutely the best constructed lawn mower I have ever owned.
Now-- a question. I have a lot of work in rough ground (not mowed) and I would like to have more ground clearance, for the deck. When the deck is in "raised" position (transport) the gauge wheels are still on the ground. I have seen photos of these machines and it apppears that it is in the design of the lifting mechanism.
I know that I can remove the deck but was wondering if this is, in fact, the way it should be, is it out of adjustment or can it be modified to lift completely?
   / Gravely 16G #2
The only adjustment on the deck lift on my 16-G is a "J"-bolt that is double nutted. This hooks into an eye bolt on top of the deck. These double nuts on the "J"-bolt can be adjusted to raise the deck until it bottoms out on the frame. Even at that the deck doesn't raise as much as I would like it to. The 16-G is a very good machine. With the engine under the seat and their low center of gravity there are one of the best for mowing steep hills.
   / Gravely 16G
THANKS I will look--What had me confused was that in all photos I have seen, the deck is in this position--even in my service manual.
I found this Gravely, with three bag bagger system, on CL, local, and I could not believe the mechanical condition it was in. Sadly the machine is badly faded but no rust anywhere:confused: It has an owner installed hour meter and the PO said it was correct --with 436 hours:thumbsup: I can believe this because it shows NO wear, not even on the floorboards! Original Belts.
   / Gravely 16G #4
These mowers are very easy to service. Just about every movable joint has a grease fitting. The forward and reverse clutches are on the outside and easily replaced. These mowers were built to last many years. You made a good investment.
   / Gravely 16G
I adjusted the rod, as you suggested and it is now at a height I like. THANKS
golf cart (A56859)
golf cart (A56859)
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
S/A Yard Dog Truck (A59230)
S/A Yard Dog Truck...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
