rtv 900 oil presure light on
   / rtv 900 oil presure light on #1
kunota man
my rtv 900 has 475 hr. on it service regular and the oil light come on at idle barely give it some fuel and it goes off. i change the oil and filter using oem stuff like allway still does it so i tured the idle up a little and its gone stay off unless i stop on a hill and give it some fuel and let off for a split second it come back on then goes off everthing seems to be running fine been like this foe a month now .any suggestions
   / rtv 900 oil presure light on #2
Oil pressure sensor might be bad. Happens on cars all the time.
thought about that.wonder how to check them
   / rtv 900 oil presure light on #4
Not sure...I'd see what it costs and just replace it. There probably is an ohm or resistance test but that's not my thing.
   / rtv 900 oil presure light on #5
Manual says if pressure drops below 7.1 lbs, the pressure switch makes contact and light comes on.
Probably just as easy to do as Tim said, replace oil pressure switch.
It is located on the drivers side below the alternator and has a blue/yellow wire connected to it. To test wire, just ground it out on the engine and with key on the light should come on.
Hard to reach and replace. So make sure everything is cool, hot exhaust will burn skin quickly.
   / rtv 900 oil presure light on #6
Well...What did you find?
haven't had time to check it yet.may go a head and order a sending unit before i look at it.wonder if taking it out and cleaning it would do any good
   / rtv 900 oil presure light on #8
I doubt it...If you've maintained it carbon build up shouldn't be an issue.
If it's not too expensive....Just swap it. No harm there.
   / rtv 900 oil presure light on #9
It's a small internal pressure switch, cleaning will not help. If you had that much gunk in your oil you'd have bigger problems than a switch. Don't fret, like Tim, I'll bet it is the switch.
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
INOP/NON-RUNNING 2007 Peterbilt 378 Flatbed Mud Mixer Truck, VIN # 1XPFDT9X37D666626 (A51572)
INOP/NON-RUNNING...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
UNUSED FUTURE 14' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 14'...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
New/Unused 78in Quick Attach Rock Bucket (A51573)
New/Unused 78in...
