Home Build Log Splitter
   / Home Build Log Splitter #11
that husky 22 ton looks nice.
They are very nice and very well built as well.
ALSO, if you happen to get the 10% off cupons in the mail, the last one I got did NOT say "excludes huskee".
It had the usual excludes husqvarna, cub cadet, etc, but no mention of the splitters. May be worth asking if you have the cupon. 10% will cover the sales tax and then a little. So maybe $970 of so OTD.
   / Home Build Log Splitter #12
I built one four years ago. 3pt powered by a PTO pump. 35 Ton capacity. I bought everything and had $1500 in materials.
I guess the first thing you need to decide is what capacity splitter do you need?? You can buy a self contained splitter for less than $1500 but it won't be a 35 Ton and will be slow. If that suits your needs then that's what I'd do. If your needs are a durable large capacity splitter I think you can build it cheaper than buying.
I'd be concerned about how slow a splitter is going to be on your tractor. For example it probably has a pump flow capacity of 6-10 gallon per minute. If you use a 4"x30" cylinder the cycle time is going to painfully slow, probably 20-30 seconds to run the cylinder out and slightly less to retract it. That's unacceptable to me. I want a cyle time around 10 seconds out and slightly less to retract. On my homemade splitter I used a 22 gallon per minute pump to get that quick cycle time.
Now I use a self contained trailer mounted splitter with a 6"x30" cylinder. It has a cycle time of 12 seconds out and slightly less to retract. That's plenty slow for me. I paid $6500 for it. Not practical unless you have a large volume need. We split 100 cords a year.
What brand of splitter is the trailer mount? looks like a beast:thumbsup::thumbsup:
   / Home Build Log Splitter #13
I bought it from Northern Tool, it's their house brand. It is totally a beast, weighs 2400lbs. I think they went to their shop manager and said "build your dream splitter and spare no cost". I added a catch table. If you have two or three people working you can split a LOT of wood very quickly. Has a four way wedge ran by the small cylinder underneath. The log lift is rated at 660 lbs and will pick up anything you can roll on it. It's only cost effective if you split a lot of wood and think of it as a long term investment. It will outlast me and my boys and probably my grandsons. :)
   / Home Build Log Splitter #14
Thanks for the info. I intend on building my own but might copy the specs.
   / Home Build Log Splitter #15
I just bought the SpeeCo 22 ton at TSC. $699.99. It is horizontal or vertical and takes a 24" log. I had to buy 2 5' hoses at a local auto parts. and quick disconnects at JD dealer. My tractor is a JD 4200 with remote hook ups on the back. I really like it. I set the tractor at 1500 rpms. Yes it would be slow for some people. I work all alone and don't get in any hurry, so that part is fine with me. It takes about 25-30 seconds to split and return. I just tried it out the other day and watched the deer in my woods between splitting. It made my wood splitting time very enjoyable rather than hard work.
   / Home Build Log Splitter #16
I concidered going the tractor powered route as well, But even with my 57 hp tractor I only have 11 gpm hydraulics. That was secondary only to the fact that I can run a 4cyl diesel engine at 1500 rpm to give the full 11 gpm for hours or I can buy a 100.00 china special 6.6hp engine and when it wears out they will only cost 80.00 cause they just keep getting cheaper. As opposed to a 3500.00 + overhaul on the international.
Just the way I came to my decision to build a self powered unit. Also now that I have the skid steer, I can carry wood to the splitter and drop it and have a helper run the splitter.
   / Home Build Log Splitter #17
Looked at them too, and without a doubt, the same purachase was on my mind. If my hyd. wear out or have a problem, I have bigger problems than splitting logs (loader, hyd lift on mower, trimmer, box blade, all 3-point and anything else that was almost the sole purpose of buying the tractor). Think you be happy with it.
   / Home Build Log Splitter #18
as far as completely building one for under $400... unless you already have all the components and steel, you won't be able to do it except maybe at used/salvage prices i'm guessing. at good new prices you're looking at $75+ for a valve, $150+ for a cylinder, and $125+ for hoses, elbows, and quick connects. you're at $350+ already, not including any steel. $400 is pretty much what it cost me to do mine last year and i did have all of the steel.
i think it all depends on what you want to do with it. if you're in a commercial business then you're justified in multiple thousands, but as a homeowner it's most likely a waste. i've split about 10 cord over the last two years, and i'm using a tiny little homemade splitter which does pretty much everything i will ever need.
this is a 24" oak log on my splitter. it was no trouble at all and that cylinder is only 3 1/2 diameter. the cylinder also only has a 18" stroke. for me, a 24" stroke would be next to useless. since i moved three years ago i have put two new wood burners in my house - a large regency f3100 stove in the basement and a medium insert in the fireplace. the basement stove can take up to 21" and the insert can take up to 18". i'm not going to cut two sizes, so i cut everything at 16" +/- so i can burn it in either stove.
because of this i went with the 18" cylinder and i built it so the gap between the plate and wedge is 19". i do most of my splitting by myself, so once i split, i let the cylinder retract while i toss the split pieces in the pile and get the next log. if i had a 24" splitter, i would often have the cylinder completely retract and then have to wait for that extra 6" of takeup each time i split -a colossal waste of time.
i'm also powering it with a 5.6 gpm pump, which will make many of the statisticians here cringe, but in my experience, it's not that bad at all. on the split stroke is may well be faster than most stand alone splitters. the reason is everyone looks at the no-load speed on the pumps. sure, you may have a 15gpm pump, but that's at low pressure and not under a load. when you hit the log, you're down to a 2-3gpm pump until you've popped the log in half and it kicks back into high gear. i'm running 5.6 gpm all the time. i'm also driving it with a 24hp engine, so there's no power issue. on the return stroke i do lose some speed to the two stage crowd since i'm handicapped at 5.6 gpm, but as i noted before i am generally a one man operation and i only have an 18" return stroke.
some people may not want to rack up hours on a $15k+ powerplant to run a splitter when a $200 engine will do, but for me (the average homeowner with a tractor) it's not an issue. the few hours dedicated to the splitting is minimal in the overall scheme. also, it's got a high stack so the fumes are overhead, and i run around 1500rpm so it's quieter than many of the cheaper 3600rpm small engines. i'm not saying it's perfect for everyone, but for me it sure was a no brainer. $400 plus labor to build it as opposed to around $1000-$1500 for a new stand alone. for me i also like having it be one less engine to maintain.
   / Home Build Log Splitter #19
and it has a Honda engine. You will be happy with that. If your tractor is less than 7gpm and you split a lot of wood, go with this model.
Again, I have a ramsplitter 16 ton with a 3.5" cylinder, and it moves good at 7.2gpm. I am happy with my cycle time. If it was 5.6gpm, I can tell you with confidence you would find it too slow.
   / Home Build Log Splitter #20
Great looking splitter, lostcause, and great pic.
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
UNUSED FUTURE FT-80R RIDE ON TROWEL (A51248)
UNUSED FUTURE...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
