bushhog 286 blade help
   / bushhog 286 blade help #1
bigde2001
tc45da
I have removed the nuts and lock washers. I can not get the bolts out and have tried all day. I used heat, sledge hammer, I have even prayed. They will not come out. Please help me.
   / bushhog 286 blade help #3
Did you spray the heck out of them with WD40 or something similar?
yes i did spray them, I went ahead cut them off.
   / bushhog 286 blade help #5
The problem is that the stump jumper moves when you hit the bolt so no force goes into the bolt.
so, support the stump jumper (jack, 4x4, something) so it can't move
Then get a pipe about the same size from the top and wail the living ***** out of it with a sledge hammer
They do come out.
   / bushhog 286 blade help #6
Most people take off the stump jumper to remove the blades bolts. Ken Sweet
   / bushhog 286 blade help #7
Thought I would tag to this thread. I think I have a Bushhog 286 as well. I finally got the blades off... 3/4 drive impact no go, 3/4Drive 4'Cheater, No go, then smoke wrench. (heated up the Nuts then 4' cheater) success!!.... Thanks to all the suggestions on this board...I was just about ready to load it up and take it to the Dealer..
Attached is a photo of the blades...My next question is, What are the guidelines to determine when blades should be replaced? I have sharpened the blades on the bushhog twice now, that I know of,,,They could have been sharpened previously, as they were the blades on the bushhog when I got it... about 5 yrs ago.
   / bushhog 286 blade help #8
Congrats on getting them off. When blades get to looking like the ones in the picture (with badly rounded corners), then it is time to replace. Ken Sweet
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
1014 (A51573)
1014 (A51573)
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52748)
Quick Attach Skid...
1271 (A50490)
1271 (A50490)
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
