Interesting JD Specialty Tractor
   / Interesting JD Specialty Tractor #21
Reverend Blair said:
With the hills around there, we could just lay the roller coaster tracks on the ground.:laughing:
Sure, we'll end the run in the valley in Fort Qu'Appelle (my hometown), and the coaster-riders can hit the Country Squire lounge for a drinkie after!!
The GPS accuracy is nuts!! Hard to imagine that we were taught to 'eyeball' the lines when spraying or seeding!! I always overlapped a wee bit, as bare spots were embarrassing for the entire growing season.....
-Jer.
   / Interesting JD Specialty Tractor #22
IIRC, the Deere system uses Differential GPS. They had a setup on display at Empire Farm Days last year and it used a base station, then sent signals to the receiver in the tractor, allowing it to see where it was better than just the standard GPS. I think they said that it was accurate to within a foot.
Aaron Z
   / Interesting JD Specialty Tractor #23
Aaron Z
I think that's similar to the WAAS system for aviation that allows airliners to fly precision approaches in near zero vis.
I wiki'd it.... Differential GPS (DGPS) is rated to 10m lateral and vertical accuracy, but actually does down to 2.5m. WAAS (Wide Area Augmentation System) is rated at 7.6m, and actually is good down to 0.9m.
They are both a form of "error correction" system that up's the accuracy of the existing GPS signals.
Absolutely amazing.....can't wait to get my hands on some hardware that'll do that!!
-Jer.
   / Interesting JD Specialty Tractor #24
Accuracy is a function of how much you want to pay. Yes, the best accuracy requires a base unit set up in the field to provide error corrections.
   / Interesting JD Specialty Tractor #25
Most farmers over 2000 acres own a self propelled these days but the deeres never really were that popular here..The rogator is always the popular one.
Although these are newer larger models pictured on this thread there are plenty of 4000 acre farms running these !
   / Interesting JD Specialty Tractor #26
They're not oulandishly expensive though, are they??? Couple grand gets you into it, no??
-Jer.
   / Interesting JD Specialty Tractor #27
Don't know what the cost is, but a local dealer has set up base stations on towers to cover six million acres with the maximum RTK accuracy. Saves costs and setup of doing that part yourself.
   / Interesting JD Specialty Tractor #28
-Jer.
Not sure which "it" you're referencing. I recall a number of $26,000 coming up in a conversation, but then not sure what that all referred to either. I believe there is hardware, software and subscription / activation pricing that comes together to form the total package of whatever one is trying to accomplish.
Here's a link to some of the components with some pricing
Select a Model
   / Interesting JD Specialty Tractor #29
Aaron Z
IIRC they are more accurate than a foot. A foot wouldn't work worth a darn for planting. I believe it is a inch or so.
   / Interesting JD Specialty Tractor #30
Accuracy with RTK is one inch. See charts in my previous posts.
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A54607)
2020 INTERNATIONAL...
2017 Mitsubishi Outlander Sport SUV (A53424)
2017 Mitsubishi...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
