Ok so how much weight will I lose??
   / Ok so how much weight will I lose?? #1
Ezlivn
Robbinston Maine
2001 JD 790
I presently have a ballast box loaded with bricks as weight for my 790. This Saturday, I'm buying a 5ft rear blade at TSC. Will this make a significant difference in my performance on snow this winter? I have no loaded rear tires but do have chains on the front. Yes I know all about the chains on the front deal but they will not be under stress...it's just for a little xtra bite for my plowing needs.
Thanks
   / Ok so how much weight will I lose?? #2
Without knowing how many bricks you have in the BB, and what the new blade weighs your question is impossible to answer...
The website doesn't say how much the blade weighs. From the picture below....that ballast is loaded and is quite heavy. I guess my question is, will the weight of the 5ft blade be enough?
I guess I'll find out the hard way.:laughing: If she spins, I'll load up the ballast.:thumbsup:
   / Ok so how much weight will I lose?? #4
The blade sits a bit further back then the ballast box. There are blades that would weigh more with the tilt and offset features and being back further.
So depending on what you bought that might give you more then the ballast box with bricks.
   / Ok so how much weight will I lose?? #5
Its always handy to have some kind of idea of the weight you carry in your ballast box. If your bricks are all the same size, just sit one on a regular bathroom scale and do the math.:thumbsup:
   / Ok so how much weight will I lose?? #6
that "quite heavy" loaded ballast looks to us to be about 20 pounds, or so.
a 5 foot blade weighs about 3 pounds per foot, ergo about 15 pounds or so.
you see the problem here, right?
wrooster
   / Ok so how much weight will I lose?? #7
the blade when down would not have hardly any weight on the tractor so you would spin when plowing.Just my 2 cents
wrooster
that ballast looks to be 20lbs huh? You're kidding right?
try more like at least 200lbs
15lbs for a rear blade? I hope you don't work for weights and measures dept.:p
   / Ok so how much weight will I lose?? #9
and obviously you are new to the sarcasm department. my point to the original poster was that is impossible to draw any conclusions from what he is telling us. without any substantive data, the only thing people can do is guess.
by the way, your shoe is untied.
wrooster
   / Ok so how much weight will I lose?? #10
I suspect you will spin the rear tires often when you drop the blade down. To benefit from the new rear blade you will need some rear tire chains and some rear wheel wt, either iron or liquid ...you pick.
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2012 UTILITY VS2DX DRY VAN (A54607)
2012 UTILITY VS2DX...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
KIDS DIRT BIKE (A53424)
KIDS DIRT BIKE...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
