3525 owner has 3pt plow question
   / 3525 owner has 3pt plow question #1
boog0909
fingerlakes area in upstate ny
John deere 5055 & mahindra 2015
looking to buy a plow for plowing a couple acres before i hit it with the disc.My question is should i looking at a single or can i use a 2bottom the soil is pretty heavy some clay . I believe the tractor weight is around 4400lbs and engine hp is 37. Any responces would greatly appreciated
   / 3525 owner has 3pt plow question #2
It should handle 2 16" bottoms quite handily. Where are you located, my daughter lives on Seneca Lake. Also when buying a used plow, make sure the bottoms are true and not sprung. There are a lot of bad ones out there.
   / 3525 owner has 3pt plow question #3
Your tractor will handle a two bottom plow no problem.
I'd recommend two 16s. Make sure you get a plow that
has good coulters and is adjusted properly on your hitch.
JOHN DEERE 35G EXCAVATOR (A51242)
JOHN DEERE 35G...
2022 CATERPILLAR 299D3 XPS SKID STEER (A51242)
2022 CATERPILLAR...
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
