No Go with Glow Plugs
   / No Go with Glow Plugs #11
Pardon me if I dumb this way, way down, since I didn't see my solution addressed.
Synopsis. I'm a first time tractor owner.... had my 2010 284 since June. As summer passed and temps dropped into the 40's, the tractor refused to start. I bought a Kats magnetic heater. That helped but not much. I assumed I did not have three bad glow plugs since the tractor was so new. I figured this tractor just didn't like the cold... I have read those types of posts here and had no other tractor experience to compare to.
Reading this and other posts, I tested my GP circuit. I ran a jumper from the battery to the GP buss bar for 20 seconds. The tractor started so fast (40 temps, no pre-heat) it actually startled me!
After more tests with the MM, I determined the problem must be with the switch. I called my dealer.
And now, the rest of the story....
It turns out I had not actually used my GP's for my first 100 hours, until now. I thought I understood my dealers instructions on the ignition when I took delivery, but nope.
What I didn't realize was that the GP heat position was in that spring-loaded, no detent, past ON, best guess how far to turn the key before you bump the starter, position!!!
I'm sure this is a big, "Duh" to most of you, but based on the information I was originally given, it was a pleasant revelation to me.
This is probably not the OP's problem, but it might help some other newb who lands here after a Google search.
   / No Go with Glow Plugs #12
It would be pretty easy to put an indicator light in the dash to show you when you activated the glow plugs.
   / No Go with Glow Plugs #13
This was the first thing I did to my tractor in 2003 when I got it.
Chris
   / No Go with Glow Plugs #14
why not just look at ammeter and watch it?
is there something better about a light?
   / No Go with Glow Plugs #15
Point being, maybe he did not turn the switch far enough? Next check for voltage at the said point. Either way should see a reaction from the current draw to the glow plugs. It is highly unlikely they all failed together unless machine has a lot of hours.Glow plugs are tough little devils, except on chevy trucks? Jy.
   / No Go with Glow Plugs #16
Some of the alternators only put out enough current to recharge the battery. It's possible that the ammeter has a rather low scale and might get pegged when the glow plugs are on.
Ummmm, the alternator isn't in the circuit until the engine is actually running.
//greg//
   / No Go with Glow Plugs #17
Ummmm, the ammeter isn't in the circuit until the engine is actually running.
//greg//
im not sure i understand what greg is saying cause he is great help
but i do know when i activate my glow plugs the ammeter does go to the negative side by alot
i can let go of switch and it goes back to the middle or very close
am i missing something greg?
   / No Go with Glow Plugs #18
You're not missing anything. My brain was thinking alternator, but my fingers typed ammeter. The mistake has been fixed.
//greg//
   / No Go with Glow Plugs #19
Otherwise, the alternator has nothing to do with the glow plugs.
Concur, but it has little to do with charging rate or meter range either. Another significant reason there's only a 30 amp meter, is that the electrical system is engineered around a 30A system fuse. Any load in excess of 30A should blow the system fuse before causing any lasting damage to the ammeter.
But if someone were to screw that particular pooch by putting in a larger capacity system fuse - let's say to install high powered lighting for example - THEN there should be a counterpart ammeter upgrade. Short of that, the system is designed to handle a simultaneous load of 3 (healthy) energized glow plugs AND a (healthy) starter motor. Probably not a good idea to try that with the lights on though.
//greg//
   / No Go with Glow Plugs #20
Tell me about the GM Durajunk motors eating glow plugs. I had a 05 that I traded after 9 months because of all the issues. Glow plugs where just the start. It ate injectors and fuses like candy. Never again. Ford Powerstrokes for me now on.
Chris
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2014 Peterbilt 337 Service Truck (A53422)
2014 Peterbilt 337...
