Block heater T1110
   / Block heater T1110 #1
MD09
King George VA
Hew Holland TC34DA
Just got finished trying to install the NH block heater into my T1110.....
The cheap bolt snapped off....
The wing on the back will not flatten to hold the heater in....
Help I some one out there has do this, what did you do to make it work or did you use another brand of block heatrer???
Thanks
Rob.
Looked at the Kats plug it looks like the NH blockheater same sort of spreading wing to hold. My problem was the "wings did not spread out enought to hold the heater in tight enough. Any Idea on how to make this work??
The only thing I have seen on this site is you have to fool around with it a bit to make work.
I am looking at redesigning the locking tab to a larger flat bar vs. the stock spreadign design. From what I can see the depth of the NH part is pretty equal to the thickness of the block. Since the wings do not flatten out the heater will not hold tight.
Anyone have any expirence with this? or do you guys just order an aftermarket and say your done?
:confused:
   / Block heater T1110 #4
The wings should project slightly onto the block wall. It still has to provide freeze protection to the water jacket casting. It only has to hold back 15psi so it doesn't have to hold with much force. All I've seen are made with the wing style. You may have a rough spot on the inside of the casting that is causing the problem. Flat bar would propably fix the one you have.
Thanks Steve,
I was think of fabing a flat bar to lock the heater in too.
Cheers
Rob.
   / Block heater T1110 #6
Thanks
Rob.
Sounds like you got the wrong part! Philips-Temro usually makes the NH block heaters. Google them and see if you can find the correct part number in their catalog.
   / Block heater T1110 #7
I had the same trouble with mine four years ago. I was lucky in that I had the old one, which had a almost-flat-stock spreader (IIRC). I think you can make one that you can tip into the opening, though you might need a longer center bolt to hold it in. The wings were bent back toward the exterior a little so tightening the bolt caused the wings to bite the sides of the casting hole. It'll take some trial and error. Not much room in there, I recall. I assume you snapped the bolt trying to get it tight enough to hold coolant? I agree the new spreader could be stronger - mine leaked instantly. NH heater kit part # was 86590117.
Jim
   / Block heater T1110 #8
Wow what a serendipitous thread! I was about to come on here and begin searching for "1110 engine block heaters".
I'm in the same boat. I need a recommendation for a bh. I hope to not hijack your thread MD. My 1110 has only been mine for two weeks, I'm just learning it's ropes. MD, or anybody else, do you know what size bh the 1110 needs? Is it a 40mm one like the katz because if so I may order one?
Thanks to anyone with info. Hope I didn't hijack.
Jonah
Update on the block heater.....
Right now it is a bit on the cool side for Maryland teens and 20s, sine I do nto have a heated shed/garage I resolved teh startign issue with a Heatign blanket..... just drape it over the hood and turn it on high for a few hours before starting. So far since the little critter is out of the elements ( In a shed) it is working OK.
Jonah,
If you are having real problems starting and after reading you expirence with the front end, you may want to investigate the glow plugs. You will have trouble starting even if only one is not fnctioning correctly. The other thing I do is cycle the glow plug a couple of times when it is real cold and mine usually starts right up. No worries about hi jacking the thread....
   / Block heater T1110 #10
MD09 .... I had the exact same scenario with my T1030 last year. I tried three times to get the OEM heater to seal ....... finally put the odd sized freeze plug back in ( that I had to wait two days to get ) ... threw the heater in the trash and vowed to not buy any more of the New Holland crap.
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
2022 30ft 20k Blazer Deck-Over Trailer (A52128)
2022 30ft 20k...
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2014 Ford Explorer SUV (A50324)
2014 Ford Explorer...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
Gator (A50324)
Gator (A50324)
