best way to cut 16ga metal and 1 inch tubing
   / best way to cut 16ga metal and 1 inch tubing #11
Crisp, easy, precise, and clean with a cut off wheel. Cuts through steel like butter. I'm from the old school. I can, if so required, do bypass surgery with a cold chisel and a hammer. Do the cut off wheel thingy and be happy.
   / best way to cut 16ga metal and 1 inch tubing #12
I have over 20 years experience doing sheetmetal work (I still learn something new everyday) and for your project the cutoff wheel as whistlepig suggests is by far the best way to accomplish this task. Besure to wear your hearing and eye protection. Watch where the sparks go because it would be hard for Santa to bring you a new shop for Christmas.
Thanks for the replies everyone, I will be stopping by Acme Tool today and getting a couple thin (.045?) wheels and will use 1 X4 or 2 X 4 clamped on as a guide----even with lots of airflow underneath--and using the cab held on the tractor with ratchet straps---it has become CLEAR to me that ANY cab is better than not cab.
   / best way to cut 16ga metal and 1 inch tubing #14
Angle grinder with cutoff wheels will do the job. Just be sure to keep the shield installed on the grinder (it's removable and adjustable). I've had cutoff blades come apart and that shield saved me a trip to the ER or worse.
   / best way to cut 16ga metal and 1 inch tubing #15
Acme tool? I thought only Wiley Coyote shopped there!:laughing:
My first choice would be the cut-off disc as well. If space doesn't allow it then a metal blade in a sawzall.
   / best way to cut 16ga metal and 1 inch tubing #16
i try not to make any sparks until i check for sure that the hose has water pressure in it.:thumbsup:
it's hard on the system (heart) trying to round up a hose, nozzle etc as the flames are licking at your equipment/building/forest.
   / best way to cut 16ga metal and 1 inch tubing #17
I must be old fashioned but I would use a hacksaw. Should cut easy.
   / best way to cut 16ga metal and 1 inch tubing #18
I would use my new Plasma cutter but it wasn't listed in the choices.
2015 Caterpillar 259D (A50123)
2015 Caterpillar...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2024 Deere 317G (A50123)
2024 Deere 317G...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
