Wood stove woes
   / Wood stove woes #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
We have a 1300sqft modifed a-frame. We have a wood stove in our mud room, and then right off that a great room with 20ft ceilings. The mud room and great room have no other types of heat. the rest of the house has electric baseboard heating, and in the basement we have 2 3-brick lp burners. we have casement windows and our doors do need replacing some gaps(the original owner had a hard time installing doors and electrical the right way).
my issues, one the smoke that comes into the house is affecting my wife.
2. the cost of the wood is free(my time only) so winter heating is free.
3. need something that will work when the power is off.
I am thinking as a temp fix to get a standalone hepa filter ~700 with shipping that will clean the air(will cover 1000sf)(the other sqft is bedrooms that we keep the doors closed all the time.
I am also thinking that if we can get more heat into the house during the day it would help with the amount of time we have to run the stove.
Possibling using this. Your Solar Home SolarSheat 1500G/S Two-Pack Solar Collectors, Model# SH1500G-BL-2Pak Your Solar Home SolarSheat 1500G/S Two-Pack Solar Collectors, Model# SH1500G-BL-2Pak | Solar Air Collectors + Heating | Northern Tool + Equipment
My wife suggested heat pump/ac mini split, not sure it that would give us enought heat.
I am also looking at some lp stoves. Money is kind of tight right now, just had to pay for a new well pump, some other electical issues, and had some other major bills in august. But i have to do something.
I figured I would throw this out there to see what you all think.
   / Wood stove woes #2
Where is the wood smoke coming from?. Solar is not an option. If you change the stove to a EPA rated give us a comment back.
Craig Clayton
   / Wood stove woes #3
You need to figure out how/why the smoke is getting into your house as you should not have smoke in the house. Is it coming back in from the chimney or from the stove itself? Burn only dry well seasoned wood and make sure the chimney has been cleaned. :)
   / Wood stove woes #4
Those 20 foot ceilings are killing you heat wise. :D We have 10 foot tall ceilings that we love in the summer. Not so much in the winter. :laughing: Last weekend I was changing a light bulb in a recessed light fixture and the amount of heat at the ceiling was unreal. :eek:
We have run our ceiling fans in reverse but the slight air movement we feel is worse than the temperature rise we got from moving the heated air. But maybe in your situation ceiling fans might work.
If the smoke is getting into the house from the doors would a quick weather stripping job work?
We have a heat pump but use the wood stove to heat the house. It has been COLD here the last week or so. This morning was 13 degrees in some areas. The house was at 18. A heat pump is better than nothing but getting a warm house with low temperatures are problematic. We just run the heat pump from time to time during the winter to exercise it. Not sure if it is needed but we just do it. :D
Unless we dump smoke from the wood stove when opening the stove door we do not get smoke smell in the house.
I am curious about those solar heaters and have looked at them for years but that is all I know about them. There is a house at NCSU that houses the NC Solar Center. Quite a few years ago we visited the center during the XMAS holiday season. It was VERY cold out that day. Part of the design of the house was a porch closed in with glass that was facing south. That room was in the 90s. The outside temps were in the 20s.
So I could see how the panels could work....
Could you install a solar radiant heating system in the house? It sure will not be cheap but there are Federal tax breaks and maybe your state has tax breaks as well to help lower the install cost.
Later,
Dan
   / Wood stove woes
Sorry should have said, the wind blows the smoke that is commming out of the chimney (outside) into the doors and windows. The smoke then gets into the house.
the stove itself i just replaced the seal around the door its not coming in from there.
I also only burn seasoned wood, and clean the chimney, and use the creologs throughout the year as I am burning the wood.
I have also been putting the weather stripping down, but the gaps in some places are bad...right now wind will get into the house if its blowing pretty good.
We do have two ceiling fans that are run in reverse to pull the heat down. its a nice trick does work great.
   / Wood stove woes #6
Not sure what the code is in your area but commonly the chimney should be at least 6 feet above the highest point of the roof. Where is the chimney located and is it above the roof line and if so by how much? :)
   / Wood stove woes #7
I would think perhaps your chimney is not extended past your roof enough ... that smoke should not "swirl" around and then get in the house. If your gaps are that bad you may need to use wood strips first before the weather strips ... got any pictures of the chimney and the gaps?
   / Wood stove woes #8
I just installed my first wood stove and started burning wood about a month ago. I'm new to this, so don't really know what I'm talking about. Having said that, here's my 2 cents.
My stove does not put out very much smoke. When it's burnig, I can stand out side and not see any sign that I'm burning on the inside. I have a pretty efficient stove, and think that has a lot to do with it. I'm also burning oak from a tree that has been dead for a few years.
My pipe goes a little over three feet above the roof. From what I read, three feet is code from the high side of the roof to the top of the chimney. My pipe comes straight up without any bends. I also read that the more bends you have, the more soot you trap.
The leaking door is fairly common. It does take a little practice and a commitment to getting it right so that you have a good seal. Sometimes you have to put down the level and eyeball them to get the best seal possible. Weather stripping is cheap and easy to add to a door.
The windows are a big issue. If you have smoke coming in through them, you have heat going out through them. It really wont matter what you do for your stove, those windows are just going to let all the heat out until you fix that problem. If money is tight and/or the weather conditions make it impossible to change them now, I would seal them shut with silicone for the time being.
Far whatever reason, I see homeowners use silicone and caulking in such a way that it doesn't accomplish anything. Be sure to get it into the open spaces and cracks. Then use your finger to make sure it's in there, and also spread out and around the ousdide of the open areas. It's cheap, so don't be shy with it.
Good luck,
Eddie
   / Wood stove woes #9
As the previous posters have said, sealing your home MUST be your first priority. You are losing LOTS of heat. We have been heating with wood from our land for years, and its wonderful! Easy to keep the interior at 75F and no smoke!
   / Wood stove woes
I know its not the widows they seal well, its the doors that are my problem then. I have frost rings around both the entry and side doors and then we have two huge slider doors that go to our deck (right off the great room), the one had at least a 1'' gap. I had to build it up with weather stripping to get a seal.
Ill try to post some pics of the issues.
as far as the chimney, it is not higher then the higest point on the house. Its on an addition to the aframe, and its roof is maby 10' from the floor where the top of the aframe is easly another 15-20' higher.
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51691)
2012 International...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2000 Kenworth T800 Roll Off Truck (A53117)
2000 Kenworth T800...
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
