JoeL4330
do you bring in outside air directly to your woodstove? if not, you should consider this (in addition to all the other things you need to correct).
When your stove burns air/smoke goes up the chimney, exiting the house. That lost air has to be made up from the outside...the more you burn your woodstove, the more you bring in drafts through all the cracks everyone has already commented on it ...seal up every crack and you have a problem, the answer to which is to bring in the outside "make-up" air directly to your woodstove ...even with the poor weather seals you now have, bring in air directly and you will see a noticeable reduction in annoying (and cold) drafts right away. This is especially important if you have another source of heat...think about it, you have to run your other heat source just to burn your woodstove (that is, to warm the inrush of "makeup air".
And, take advantage of all the other suggestions, too.
