Suspension Seat for PT 425
   / Suspension Seat for PT 425 #1
FAZTRAC
Flatistan and Tenn. (part time)
PT 425 & john deere hydrostatic, DR Brushcutter 17 HP!!!!
New PT 425 owner here. Has anyone found a suspension seat that works well in the space of the PT.
The stock seat is like riding a rock.
No doubt this has been covered already somewhere in these forums, but I have not located.
Has anyone found a particular seat that works well with PT configuration?
Thanks
   / Suspension Seat for PT 425 #2
That is one thing I definitely want to do, as the the PT seat leaves something to be desired. Biggest mistake I made was paying $125 for those stupid arm rests. I should have put that money in a new seat. I also dislike the seat belt. A retractable one would be so much better.
   / Suspension Seat for PT 425 #6
I am not sure how much higher I sit. The 1850 has the seat tilt mechanism and i believe the slide rails were part of the original seat. If i had to guess, I would say 1.5 - 2". If i remember, i will measure from the bottom of the suspension mechanism to the top of the seat. The seat has a contoured profile so it will be hard to guess where to measure.
Ken
   / Suspension Seat for PT 425 #8
Thanks, Moss. Saves me from measuring. You can save some height by not using the slide rails. I have never adjusted it since the first time.
The TSC seat is much taller than my setup. There is no way i could have used it.
Ken
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
E-Z-Go Workhorse Utility Cart (A55851)
E-Z-Go Workhorse...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
