Green Horn that got a steal of a deal
   / Green Horn that got a steal of a deal
A tiller like I have in my signature line should work well for you. It is a 48" tiller, so it will cover your tire tracks well(as your tractor is 45 inches wide).
I noticed that you have 3 PTO speeds, use the lowest setting as the tiller is designed for 540 rpm.
I also noticed that your tractor is designed for Cat.0 or Cat. 1 implements, I would stick with Category 1 implements. That way if you get another small tractor in the future, the implement will work.
Thank you! That is really helpful!
Could you or anyone direct me somewhere to find used Cat. 1 implements?
Perhaps, in the future, if I can save up (I don't like debt!) I would like one with four wheel drive, lights, and front loader. All of which I imagine is expensive. Anyway, I am very grateful for the one I have.
What a difference two zero's make. Now sounds like a much better deal. :tractor: :cool2:
I said I was green horn. :confused2:
   / Green Horn that got a steal of a deal #14
Being a teacher (and there are many who are better than I) does not magically grant you powers of perfect spelling. I wish it did.
No, right clicking does!
Just pokin fun, sorry if you took it the wrong way. I'll be sure to put smilies all over my comments for ya.
   / Green Horn that got a steal of a deal #15
:D Depending on where you live.... Craig's List Craigslist > Cities is a good place to start to look for use...
Right, but must I buy Bolens implements? Or can buy any G1 brand?
I took it just fine. My comment to you was sincere. Thanks. I apologize that the internets lack inflection.
   / Green Horn that got a steal of a deal #17
You can pretty much use any Cat 1 3 point implement, as long as the tractor can handle it. I mean you wouldn't be able to pull a two bottom plow. A tiller will likely work OK but won't get very deep.
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53472)
2017 KINZE...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
