PTO generator/shaft question
   / PTO generator/shaft question #1
Freds
NW PA
Kubota L3130HST & ZD326s
I ordered a PTO generator yesterday. I did not order the PTO shaft, or tumbling bar thay called it, because I figured I could find one for less than $245. Here's the generator if anyone is interested. Voltmaster PTO15/12 PTO Generator - PTO15/12 - 12 kW Tractor-Driven PTO Generator (540 RPM)
The local TSC apparently doesn't have any PTO shafts with the quick disconnect on both ends, so I went to Northern Tool's site and am looking at two shafts, one for 100 bucks and one for 270. The $270 shaft was featured on their generator's page and does say it is for a PTO generator, but I don't see why the cheaper shaft won't work. The cheaper shaft is rated to 35 hp and I've got 29 at the PTO. And the length will work, too. It is not the light duty fertilizer shaft, as you can see. NT's tech support was of no help. And so I come to you :)
Here's the two shafts.
NorthStar Waltersheid PTO Generator Driveline 60 HP | PTO Generators | Northern Tool + Equipment
Braber Equipment General-Purpose PTO Shaft Assembly 40in. Collapsed Length, Model# 69.888.004 | Tractor Accessories | Northern Tool + Equipment
What do you think? What do others here use that have generator's and tractors in my class? Is there a definitive difference in that much of a price difference for my intended use?
   / PTO generator/shaft question #2
Freds....I have a NH tC - 29 ---29 HP and I use it with a 20KW PTO generator and I would not hesitate to buy the $99.00 general purpose shaft..if that helps you at all...operating a PTO generator is not even near the strain that a bush hog puts on a shaft if you think about it...
Thanks Brin. That's exactly what I told NT, that there wasn't any real strain, so why the huge difference.
I just needed to hear someone else back me up, lol.
   / PTO generator/shaft question #4
I don't know what you are planning on connecting to your 3 PT hitch but TSC has a nice inexpensive carry all that your generator will mount on real easy...Good Luck with it..
Thanks. I already have a picture printed out of that one and a length of angle iron on the way. I figured it was a nice project to help justify a little welder I just got.
   / PTO generator/shaft question #6
Great ! I know it will work out just fine. That sure looks like a nice Generator..:thumbsup:
One other tip...I just thought of ...The angle iron is no doubt for the legs for the carry all...be sure to attach the carry all to your 3 pt. on level ground and then raise it up with your generator sitting on it and the new PTO shaft attached and be sure the PTO shaft is completely level with the ground when you measure for the length of the legs you are going to weld to the carry all..You do not want much of an angel , if any, on the shaft. The shaft should be straight....
Good tip. I saw somewhere within 10 degrees. It's nice that you mentioned it in case I hadn't. No welded legs though. I figured one leg on the tractor side of the carry all to bolt on in the middle. That will prevent any drift down, which my 3PH never does, but just in case. And that will allow me to still lower my carry all to ground level for dragging heavy stuff onto it, like the generator. I'll have the generator bolted to a piece of 3/4" plywood or something. Eventually I might make something just for the generator. Something like the 3PH stand on the site I am buying it from.
Thanks on the generator. I'm hoping it's as good as people have said of the NT one, and it's cheaper and made in America.
   / PTO generator/shaft question #9
Freds,
I'm not sure I follow you...but remember that generator has to be secured ..there is a lot of torque when it starts up and if you are just mounting it on a sheet of plywood and are going to just set that on the carryall and not bot it down - well then I think you are headed for trouble and a twisted shaft and maybe even damage to your pto shaft on your tractor..
The carryall should have legs and sit on the ground with the shaft as near horizontal as possible and the generator should be bolted to the carryall.....
   / PTO generator/shaft question #10
The highest reaction torque you'll get on the generator mounting frame will occur when its running at a high current load and you disconnect it at the breaker(s). It can even flip over an alternator on a trailer.
As far as the quick disconnects go, I feel you only really need them at one end. Otherwise, it will disappear to another machine and be lost on the cold dark night you need it.
2014 Jeep Grand Cherokee Laredo SUV (A48082)
2014 Jeep Grand...
2016 Toro Reelmaster 3100D 72in Reel Mower (A46684)
2016 Toro...
300 Gallon Tote (A49251)
300 Gallon Tote...
Woods RD7200 Mower (A49251)
Woods RD7200 Mower...
Ford 9000 Truck (A47369)
Ford 9000 Truck...
2017 Ford Explorer Police SUV (A48082)
2017 Ford Explorer...
