SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,730
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
PTO shafts that run at a fixed angle should be well off 0 degrees/straight. Straight does not get the ujoints to move enuf the keep the lube refreshed on the needle bearings. Give it several degrees ... up to 10.Good tip. I saw somewhere within 10 degrees. It's nice that you mentioned it in case I hadn't. No welded legs though. I figured one leg on the tractor side of the carry all to bolt on in the middle. That will prevent any drift down, which my 3PH never does, but just in case. And that will allow me to still lower my carry all to ground level for dragging heavy stuff onto it, like the generator. I'll have the generator bolted to a piece of 3/4" plywood or something. Eventually I might make something just for the generator. Something like the 3PH stand on the site I am buying it from.
Thanks on the generator. I'm hoping it's as good as people have said of the NT one, and it's cheaper and made in America.
larry
