slip clutch ?
   / slip clutch ? #1
vaskeet
camden Nc
Kubota l2250
How do you take care of your impliments with slip clutches my tiller manuel says to loosen bolts until clutch slips then retighten to ensure that clutch is not rusted solid prior to use. does anyone use an lube or oil on the clutch?
Randy
   / slip clutch ? #2
How do you take care of your implements with slip clutches my tiller manual says to loosen bolts until clutch the slips then retighten to ensure that clutch is not rusted solid prior to use. Does anyone use an lube or oil on the clutch?
Randy
Randy N0, NO, NO, NO, NO, NO!!!!!!
If you oil it will not work at all for you, and you will be stuck replacing the clutch plates.
All you need is a bit of rubbing alcohol to clean it after you lossen it and then tighten it back up, as it will wash the dust away and then dry off.
leon
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
TEST BID LOT (A50775)
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
