Loader dirt and gravel moving
   / dirt and gravel moving #1
rookiefred
Member
NW Davie County, NC
Kubota Grand L3240
My tractor cmae with a tooth bar. Should I remove it to move dirt and gravel? My barn/tractor shed/workshop is done. They set the power pole Monday, it passed elect insp Tuesday and I met with the power folks on Wednesday. Hopefully, the underground will be run this coming week or next. I parked the tractor in the barn for the first time Friday. Had to wait for the concrete to cure and get some gravel up to the edge of the concrete.
I don't have a box blade yet, maybe Santa will help with that. Thanks for any advice. It could not get much better.
   / dirt and gravel moving #2
If I had a tooth bar I would put it on for moving dirt and gravel.
   / dirt and gravel moving #3
If you are digging into the undisturbed ground, you need teeth, if you are loading from or spreading a pile of loose material, you shouldn't need the teeth, probably don't want them. If you use the rippers on a box blade, a plow or a tiller to tear up the ground first, you could dig some without a toothed bucket. If you need to remove a few inches of topsoil over a fair sized area it may be easier to keep the depth uniform by plowing or tilling then removing the soil layer without using the teeth. Unless loading with a track loader, or large wheel loader, I'd tear the ground up before digging in, any time it is possible.
   / dirt and gravel moving #4
All of this mentioned above would be easier just using a tooth bar.
   / dirt and gravel moving #5
Yes, it might be easier. Probably depends on the soil type. Spreading a new topsoil or gravel pile, if you grade with the heel of the bucket, or with the bucket level, the tooth bar shouldn't be a problem. I have seen several TLB loader buckets with a cutting edge welded (horizontal) on the heel for grading or backdragging.
   / dirt and gravel moving #6
The only time I would remove a tooth bar would be if I was trying to get a real smooth surface (backdragging), or for removing snow.
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2025 LandHonor RB-14-78W 78in Rock Bucket Skid Steer Attachment (A49462)
2025 LandHonor...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
