Hoophouse project
   / Hoophouse project #1
looknlearn
Buffalo NY
Kubota B7800, 1953 Economy King 2409
I have finally gotten around to resizing and orginaizing some of the pictures of our hoophouse raising. I hope these are a good size for those with slower internet connections. If not let me know.
We selected the place for the hoophouse to maximize sun on the hoophouse and the keep it away from trees which might drop a branch and damage the plastic.
So with the location selected and it measured out with stakes and string we put up the first hoop to see how it was gonna work.
Once we had it figured out Dad started framing out the end in that first hoop.
Then we drove sections of 1 3/4 inch (about 4.5 cm) in the ground for the legs of the hoops made of 1 3/8 inch (about 3.5 cm) to slip into.
While the layout was figured out and the small pipes were being cut and driven into the ground some of the guys were bending the hoops out of two sections of pipe which fit together at the ends. Unfortunately there were no pictures taken of the pipe bending jig but I tried to describe it here.http://www.tractorbynet.com/forums/rural-living/188810-frost-has-killed-my-garden-3.html#post2157094
Once all the short larger pipes were driven into the ground it was simple and easy to grab a hoop and insert each end into the pipes and then repeat with the next one.
Once enough of the hoops were installed some guys started working on the bracing down the ridge.
Once the all the hoops were completed the other end wall was built with a single door and framing for a vent in the future.
I think that was it for the first day.
The following day we did much of the bracing and plywooded the end wall.
We attached 2x4's along the first bend on the walls (see left wall in above picture) to attach the plastic to and for a solid attachment when we made the sides roll-up-able at a later date.
This was our completed hoophouse before the plastic was put up.
Here is what the completed hoophouse looked like when we put the compost in, right after planting, as it grew, and finally the jungle later in the summer.
Here is the exterior in the summer and the rock pile. We installed roll up sides earlier last summer. These pictures were from last summer.
   / Hoophouse project
The doors and the vent were found at Buffalo Reuse, a place which disassembles old abondonded houses and sells the parts pretty cheap at a warehouse. Great place.:thumbsup:
I'll try to add some details later about tying up the tomatoes and how we did that and about the roll-up sides.
   / Hoophouse project #4
Excellent job!
Tell me, looknlearn, are You able to get Your tractor with the attachment inside the hoophouse to plough up or to till the soil? I mean, is the doors' width enough to get it in?
   / Hoophouse project
wonderful write up, thank you very much.
Thanks and you are welcome.
Excellent job!
Yes, the economy tractor fits though the front door with the wheels narrowed. The wheels will narrow to fit behind a 4 ft snow plow and they will also get quite wide. I worked up the soil in the hoop house originally with the tractor and a two tined subsoiler type implement which went down about 12 inch into the soil. Pulled out many rocks and chunks of old house foundation.
   / Hoophouse project #6
The idea of my next spring hoophouse project is, that it could be shifted to any place of the tilled soil. The weight will be so that 2 persons could lift it and easily carry to the place required.
This hoophouse will provide our family by greens.
   / Hoophouse project #7
Remember, anything two people can carry by them selfs, mother nature can and will move by her self. :D
Wedge
   / Hoophouse project
That is a good idea. We are thinking of a way to move our hoophouse to a few locations but we have not figured out a way. It will be especially difficult with the solid end walls.
An idea to solve the problem that the previous poster, wedge40, brought up is to drive T posts into the hround at each corner to lash the hoophouse to. Those post are not to difficult to remove with a little work or a tractor 3point.
Btw, I like your stick figure guys carrying your hoophouse in the file you posted .:thumbsup:
   / Hoophouse project #9
Nice job.
I will show my ignorance: How does the hoophouse help you? E.g., does it lengthen the growing season by keeping the temperatures up in the fall and spring? And if it does lengthen the growing season, are you able to plant two crops?
I assume the fabric lets in sufficient sunlight to grow the plants?
Does it keep the rain from the plants?
I would enjoy learning exactly how you use it.
Thanks.
   / Hoophouse project #10
Wedge
I'll ask Mother Nature not to do this the way Tucker has adviced. :)
2012 KENWORTH T660 ROAD TRACTOR (A57192)
2012 KENWORTH T660...
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
1841 (A57192)
1841 (A57192)
