3pt Linkage easy hitch frame
   / 3pt Linkage easy hitch frame #1
OzGrasshopper
Western Australia
John Deere 3120
Hi All, don't know if this has been posted up somewhere & i can't find it, but for those of u with heavier 3pt linkage implements that r hard to push about to line up 3pt linkage pins ect, i've made a simple wood frame to go under my slasher (i think u might call these cutters in US) so i can get it on & off easier and store it where ever i like in the shed. my frames very simple, made from old pallets, being 2 4"X2" timbers 3ft 6" long running parallel, joined by 2 6"X2" timbers to whatever width ur implement is. i'v mounted 6 swivell wheels (3 each side) to underside of 4"x2"'s (used 4 larger first, but found 6 smaller at same price were more easy to move implement around on). so cheap to make & easy to use that i made a smaller one for my ballast box. just an idea, saves me a lot time hitching & unhitching. also being out of wood, i can easily lift it about the shed when the implement is on the tractor. cheers OzGH
   / 3pt Linkage easy hitch frame #2
And the pictures are.............where?
carrier pigeon & old copper wire out here - line speed none existant mainly backwards.... but big govt promises of a National Boardband system in next ????? years - then i'll do pics...if i'm still alive:laughing:
   / 3pt Linkage easy hitch frame #4
Understood. Thanks for the post. I'll use my imagination.
HI GWD, if I can get someone to take a pic & take it to inet in town, they may post it up 4 me - it is a real simple frame & with the gear u've got listed, i recon u'd be happy to make a few up- really only takes about 1 hr once u have the materials on the floor of ur shed - i use tech screws to hold it together, wheels have own bolt assembly with the pack. once the weight of the implements r on it, it won't move - merry xmas to u. cheers OzGH
Hi All, here are 2 pics of the 3pt linkage frames i have 1 for ballast box other for slasher - very simple - very handy.
   / 3pt Linkage easy hitch frame #7
Looks good. Thanks for the extra effort to post the photos.
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
2010 Club Car Precedent Electric Golf Cart (A55758)
2010 Club Car...
2010 GLOBAL TRI AXLE HAUL TRAILER (A55745)
2010 GLOBAL TRI...
2011 Ford F-350 Knapheide Service Truck (A55852)
2011 Ford F-350...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
