TK100M slope question
   / TK100M slope question #1
dmiletich
Member
New Holland TK100M
I just purchased an almost new TK100M tractor. It is a crawler type and is New Hollands mountain version. Since a large part of my tractor work I do is disking fairly steep hills, I was wondering if anyone has an idea as to what is the maximum degree I could disk. New Holland will not give out that information, all they say is the crawler mountain tractor will work hillsides that are 20 degrees steeper than a wheel tractor, whatever that means. The tractor is 69" wide, has 18" grousers and I am told weighs about 10,000 pounds total. Any information would be appreciated.
   / TK100M slope question #2
You have to know the location of the center of gravity and the total width of the machine to even take a stab at that number.
The total width of the tractor is 69". New Holland told me the center of gravity is dead center of the width, which would be 34 1/2". From ground to center of gravity is 46 1/4" in height.
   / TK100M slope question #4
Given those dimensions, you should be able to take a maximum of 36.3° slope (arctan 34.5/46.25 =36.3°) to be at the threshold of tipping with no other loads considered. That's about a 75% grade.
   / TK100M slope question #6
I checked with NH, the allowable slope for a TK series is: uphill 28 degrees, downhill 20 degrees, sidehill 30 degrees.
Sorry it took so long to reply.
Thank you very much for the information Jbrink64. They told me at the New Holland dealership that information is not given out. Thanks a lot.
   / TK100M slope question #8
Strange your dealer told you that, that's the kind of info that should be given.
On a side note, those angles are not tipping angles, but engine safe operation angles, provided the oil level is full.
   / TK100M slope question #9
Some dealer personnel don't know where to access that info, or won't bother to do it.
Cushman Utility Cart (A55851)
Cushman Utility...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
405 (A52706)
405 (A52706)
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2014 Ford Explorer Limited SUV (A55853)
2014 Ford Explorer...
