Does a 54" deck cut and mulch as good as a 42"
   / Does a 54" deck cut and mulch as good as a 42" #1
par4n1
Richmond, Va.
Deere x575
All things equal will I loose any cut quality or mulching ability with a 54" deck v/s a 42" Deck? I need a new mower and I have found a deal I cant pass up but is has a much bigger deck then I need. I mowed in the past with a 46" but after the loss of my mower I had decieded to go with a smaller, two blade42" deck.
Geesh now this great deal has me going the other way. Any pit falls with the 54"?
Thank you
   / Does a 54" deck cut and mulch as good as a 42" #2
The 54'' I think is the better cutting deck, then the smaller ones. I got 2 54'' decks and a 48'' deck. Always cut with the 54's unless I'm using the tractors for some else. Plus you get done a little faster!!
interesting, I would have thought a smaller deck to have more of a finnished look. I figure 10 laps around the yard and I am done. How about mulching with a john Deere mulching kit? I can't imagine bagging with out a power flo.
   / Does a 54" deck cut and mulch as good as a 42" #4
I don't have a JD mower, but I think the answer depends at least in part on how level/smooth your lawn is.
The lawn at my farm has several swales. I switched from a 42" RE mower to a 61" ZTR mower this past summer. The wider mower deck "spans" some of the swales and leaves an uneven cut -- the grass is left longer in the bottom of the swales. I'm not a lawn fanatic so the reduced mowing time of the wider deck more than compensates for the uneven cut.
Just my :2cents:
Steve
   / Does a 54" deck cut and mulch as good as a 42" #5
Just my :2cents:
Steve
Exactly, but I still would never go smaller than the 54 I have on my X475. Love that mow deck.
2017 Chevrolet Express LT Passenger Van (A51692)
2017 Chevrolet...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2008 JLG SKYPOWER 800AJ MANLIFT (A51246)
2008 JLG SKYPOWER...
