Everlast PowerArc 200 Arrived Today
   / Everlast PowerArc 200 Arrived Today #11
I only use the old school helmets. I'm not going to pay $5.00 for a clear cover lens! I started out with a Huntsman, (in school) went to a Fibre-Metal Tigerhood with hardhat adapter, (wore them for years) and now a Huntsman 700. I have tried a couple auto lenses that fit in the 2 x 4 1/4 helmet, I can see where they really help with aligning the rod over the joint before you start. But I went back to the old Lincoln Super Visibility.
The hot start is very nice, I wish it was just a little hotter, but it does work great for restarts.
A little trick you could try to help you with starting a new rod, keep a little piece of scrap metal with you, just before you're ready to start welding, stick the new electrode to the scrap piece for a few seconds, this will warm the rod up for you. It really helps!;)
   / Everlast PowerArc 200 Arrived Today #12
Mark,
I noticed the green color of you welders... if you
leave them in the sun will they ripen... :thumbsup:
   / Everlast PowerArc 200 Arrived Today #13
Hey Shield, I have the PA200's little brother the PA160, and I really like it a lot, I haven't fired up my Lincoln AC welder since I got the Everlast:thumbsup:. My welds are looking better the more rod I burn, and burning rod with the PA160 is fun! I am not going to bury the Lincoln, yet, I am hoping to sell it to someone who wants a hernia:laughing:
James K0UA
I finally got to play with the PowerArc 200 today.:) 039 (800x450).jpg
037 (800x450).jpg I am a very amature welder but I really enjoyed running some beads with it.:thumbsup: I think the first project will be making some custom kidding pens for the goats this spring.:D
   / Everlast PowerArc 200 Arrived Today #15
Hey Hoos, What rod is that you are running?
1/8" 6013.
   / Everlast PowerArc 200 Arrived Today #17
I find I'm setting my current readout equal too or close to the rod diameter. How about you?
I tryed everywhere from 65 to 115. I like that as a rule of thumb. 3/32 = .093, 1/8" = .125 and 5/32" = .156.
Do you have a PowerArc?
I sure do like this welder!:D I like it well enough I might be able to practice regulary enough to weld decent, believe me I need a quite a bit of improvement.:laughing:
   / Everlast PowerArc 200 Arrived Today #19
   / Everlast PowerArc 200 Arrived Today #20
Yes. PowerArc 200. Got it last week or so from Mark.
I've noticed it likes a shorter arc than an xformer welder. My Linde HeliArc 250 is in the repair shop and may be DOA.
It looks like you can run a bead so I'd get some 1/4" plate scraps and make T joints, start running fillets. There is a lot of talent on TBN so I'm sure the guys can answer any questions that come up.
I like doing small stuff with stick when most people would use TIG.
Made this loader 3rd function switch box from a piece of 1"x1" tube. Cut a pie shape out and welded it back. Welded on a split shaft collar for mounting.
M998 (A55852)
M998 (A55852)
2020 CATERPILLAR 259D3 SKID STEER (A52707)
2020 CATERPILLAR...
Bomag BW213D Smooth Drum Vibratory Soil Compactor (A55851)
Bomag BW213D...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
2007 Ford E-350 14FT Box Truck (A55852)
2007 Ford E-350...
