Komatsu D20P-6 Steering problems
   / Komatsu D20P-6 Steering problems #1
gene0522
Komatsu D20P-6
My machines Left side will not pull. Tried adjustment screw for both sides.
Took off sprocket and housing behind sprocket, everything appears fine. All bearings, shaft and gears look good. Where should I go from here?
   / Komatsu D20P-6 Steering problems #2
Your steering clutches are bad and needing replacement. Do yourself a favor and get a set of service and parts manuals and you will be good to go.
Thanks for your response and advise.
   / Komatsu D20P-6 Steering problems #4
:laughing:
were can i get a repair book for a d20p-6
   / Komatsu D20P-6 Steering problems #5
were can i get a book on d20p-6 bulldozer a repair manual i have a service manual it does't give any info.
   / Komatsu D20P-6 Steering problems #6
I did a quick Google search, and saw more then several of the Jensales reprints, chassis specific for around $125.00.
Also on ebay someone has a CD version, of it says complete manual for $29.99.
   / Komatsu D20P-6 Steering problems #8
Mabe not!!! I have a D31P-20 ,,same problem no power to left side of track ,,,steering cluches and plates oll at least 75%,, new o-rings for the 2 pistons that push clutch arms,,what next????
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2014 TRAIL KING INDUSTRIES TRIAXLE RGN HG SERIES W/STINGER (A55745)
2014 TRAIL KING...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2020 GENIE TZ-34/20 ELECTRIC PORTABLE SCISSOR LIFT (A52705)
2020 GENIE...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
