What tube for 11.2-16 R1
   / What tube for 11.2-16 R1 #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
I need a tube for one of my rear tires... 11.2-16 Dyantorque II, but I can't seem to find one specifically called out for this size. I'm sure there's a tube out there that would fit this application. Can anyone help out here?
   / What tube for 11.2-16 R1 #2
You can just use an automotive tube as for a light truck. A 265-16
or 285-16 tube will work fine. Have you tried plugging your leak(s)
externally? I have had lots of success with that method.
Not possible in this case. Slow leak(s) through weather check cracks very near the bead. A good amount of tread left, so I'd like to get some more use out them before I replace them.
If memory serves me correctly, a 285/75 R16 tire has a section width of just a little over 11 inches and is just under 33 inches tall. To the best of my searching ablility, an 11.2-16 ag tire has a section width of 11.2 and is about 35.5" tall. So is the 285-16 tube close enough to work? If it is, my local farm supply store has some implement tubes with a heavy duty valve stem that have "33 x 12.50" printed on the side. Do you think these implement tubes will work in my 11.2-16's?
   / What tube for 11.2-16 R1 #5
Yeah, in terms of size, you don't have to be right-on for tubes. Those
are plenty-close.
I have purchased 4 new DynaTorque IIs before, and they were
reasonable, but ONLY Goodyear makes that size. And for how long?
are plenty-close.
Yes, you're right about the tires... Goodyear is the only one I've found that makes that size. As soon as I can scrape up the extra cash, I intend to buy a set of them and stash them away in my basement (climate controlled and no UV) until I finish wearing this set out. That way I'll be assured that I have a replacement set when the time comes. I can get them from a local tire distributor for about $290/ea.
Thanks for the info on the tubes. For $30, I can get a lot more life of the tires I have without having to air up the tire everytime I want to use the tractor. What pressure were you running your DynaTorque II's at? I've been running them at about 12 psi so they will squish out some for a better footprint and better traction.
   / What tube for 11.2-16 R1 #7
I ran them at the max pressure noted on the sidewall. New, and with
my backhoe always mounted, I got fantastic traction, enough to free up
my stuck Kioti (R4s) a few times. The max is prob 14 or so, as I recall.
It has been several years, but I was able to find an internet tire dealer
in Illinois that sold me DT2s for under $200. Check around.
If you stay off pavement, you should get thousands of hours of life on
new rear tires. (The fronts are cheap, BTW.)
I believe max. pressure is 18psi on 11.2-16 DT2's.... but I would have to double check. I do not have a backhoe, but am considering loading the rears with RimGaurd as well as carrying a weight box for FEL work.
I had to order front tires for my 955.... 7.00-12 R1's and they were about $100/each. Only ones I could find in short notice were Titans.
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
