RV Home
   / RV Home #1
ctpres
Gold Member
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Behind in posting projects. Had travel trailer and built simple sunscreen cover for it at one side of house. House sits of raised pad so I just built cover on same pad. Trailer wasn't that heavy so I just towed it over yard.
Traded trailer in for motor home which is MUCH heavier and taller. Wouldn't fit under it and left ruts in yard. Solution - new 300 foot crushed concrete drive and removed dirt under cover till new toy would fit. Got carried away with trying to make drive look nice with curves. Last curve was to close to cover and not enough room to get it in/out without a lot of manuvering. So now modifying retaining wall for more entry room. Retaining wall is just landscape timbers pinned together with 3/8 inch rebar instead of long nails and tied to each post with 1/2 threaded rod. Structure you see is as built for trailer, once entry/exit problems resolved I will extend cover by about fifteen feet and put on new top (beams laying across wall are the new posts.) Trailer simply had sun screen on top but I might get fancier with real roof. Think if I had a do-over on this one I would tear down old and build new instead of being so cheep and trying to use old.
   / RV Home #2
Motorhome, driveway and carport all look great!! :thumbsup::thumbsup: Beautiful property too!! :thumbsup::thumbsup:
We are in the travel trailer mode but would love to be in the motorhome mode - maybe someday.
Regarding the driveway - Do you mind telling me who you used for the crush concrete and the approximate price - instant message if not comfortable blasting it on the internet. We used Sprint over at 36/Koeblen Road off 59 for our select fill. We weren't sure who to use for our driveway material? Did you put anything beneath the stone? Does it rut up when you drive on it?
   / RV Home
Travel trailers are a lot cheeper all the way around-stay there until you are POSITIVE that camping fits your family. But once you you do go to motorhome you will love the difference.
I used Terra TX GS ground stabilization geotextile at $411.35 for 432'x12.5 If you don't need a lot I may have 100/200 or so feet left. Call Todd at Hanes Geo Components in Houston @ 713-957-0200.
I actually used washout concrete and it was $1,250 for five (big truck don't remember yards capacity) loads. Delivered by Mr Wilson cell 281- 831-5122. Have known him for years. He helped me with our original driveway almost ten years ago and NO rutting. Once I saw how easy it was I did this one by myself.
   / RV Home
Three days work and things not moving real fast. To continue with original building plans I had to disassemble a lot of the original sturcture. One mistake on original build was to use carriage bolts. Ever removed 8 inch carriage bolt from 7 inches of wood? Side rails are 2x4 inside and 2x6 outside with staggered joints. Cross beams are 2x6 sitting on the 2x4 and notched at 2x6. Adding about 7 feet to each end, finished size about 35 feet long. Original cover was just flat solar screen. This time I might go with silver tarp top. As usual with this kind of project - money counts and labor dosen't. Big difference this time is COST of RV under cover.
   / RV Home #5
Interesting. I've seen metal covers for RV's, but can't think of one done like yours before. Is a silver tarp just what it sounds like? I'm curious how you will keep a tarp tight over your lumber so it sheds water and doesn't form a buch of mini swimming pools?
The background of your place looks really nice. Love the rye grass and open views that you have between the trees.
Eddie
   / RV Home
Eddie
Going to waterproof anything will require a raised ridge down the center. Pretty sure these tall 4x4 posts won't support a metal roof in heavy winds so without major changes tarp is only answer I can think of. Plan is for three 12x20 or so tarps with each 12 foot end rolled around 2x2 and 2x2 secured to 2x4 running lenght of structue on each side. Keeping it tight will probably be done with some kind of vertically adjustable ridge. I usually solve these kind of problems as I go. Using three tarps keeps cost down and will provide flaps for wind pressure to escape (I think)
Thanks for the kind words Eddie>
   / RV Home
It fits! Went from 21 foot to 36 foot structure. Some braceing to add and need time to think about roof. Leaning to silver colored tarp on PVC hoop roof. For now I am leaving excess on poles for possible end cap framing.
   / RV Home #8
One thing you may want to consider is coming down the side far enough to keep the sun off of the motorhome. I have had a few travel trailers and motorhomes and the sun is very hard on the fiberglass sides.
   / RV Home #9
what about using springs on one side to hold tight? just an eye hook to the post and your tarp holding lumber i would but on the down wind side so it does not allow the tarp to fly up to much
just thought bungy cords are cheaper than springs
   / RV Home
Have been thinking about that. During this remodel I have been concerned about wind, not so much daily but during storms. I could enclose completly but I don't think those tall 4x4's will withstand much stress. If something bad happens to structure with RV under it - monetary damage would be far greater than weather or sun. Do I worry/think to much? Maybe a row of treated wood lattice panels around the the top?
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
