Largest Garden Tractor?
   / Largest Garden Tractor? #1
logdog
The Thumb, Michigan
Kubota L3700SU & BX1860
Just out of curiosity, what is the largest garden tractor? The Deere 400 series? Simplicity 9020? The subject came up at lunch today and I figured I would get other people's input.
   / Largest Garden Tractor? #2
Cadet 982 or super series chassis is as big a model as you mentioned but then there was the 185 cub lowboy or was that the first compact?
   / Largest Garden Tractor? #3
I saw a 4 cylinder water cooled wheel horse a few years back with a 60 inch mower deck if I remember correctly
It does kinda bring up the question of where is the line between a garden tractor and a subcompact.
Did it look like it was original or a converson somebody did?
   / Largest Garden Tractor? #6
They did build some back in the seventies I believe with four cylinder gas engine. Good units we still have a couple around.
   / Largest Garden Tractor? #8
The garden tractor is derived from the sit-on lawn mowers of the 50s-60s suburbia. A machine built around a mower deck as its central core. Just build them a little bigger and now they can blow snow and till the "garden
Compacts are derived from larger farm tractors whos main purpose was ground engagement. Build them a little smaller and now they can be used for a multitude of applications where a farm tractor doesnt fit.
I think a good rule of thumb is cat.0 vs cat.1 capability.
   / Largest Garden Tractor? #9
I don't see there is much gained from trying to differentiate where the lawn mower / garden tractor / compact utility tractor separation/overlap might be.... seems there was such a round table discussion a few times before that doesn't produce much useful information. :D
To some a lawn is a garden, but a garden isn't a lawn. :confused3:
Whatever :)
To go back to the original question, what would be the biggest? Tractor data doesnt list the measurements for alot of them.
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
23222 (A50323)
23222 (A50323)
