Can I clean oil off a V-belt?
   / Can I clean oil off a V-belt? #1
pennwalk
Lancaster PA
Yanmar 186D
I have a project GT 275. I lent it to a neighbor to tow a small cart to haul firewood. The v-belt that drives thew hydrostatic came off the tensioning idlers yesterday. I got it put back but I noticed that the belt was coated with dirt and oil. The engine was leaking oil when I got it. Would it be a waste of time to take it off and clean it. If not what should I use to clean the belt.
Chris
   / Can I clean oil off a V-belt? #2
Use some brake cleaner or carburetor cleaner on it.
That stuff evaporates real fast.
   / Can I clean oil off a V-belt? #3
Waay back we did like above with a solvent and the re-installed the belt. Then, with the engine running we held a bar of soap against the "V" part of the belt. For whatever reason, belts that had residual oil would not slip or squeak.
   / Can I clean oil off a V-belt? #4
There are tons of brand name brake cleaners on the market, this is what I use.
For me, it is very easy to find.
images
   / Can I clean oil off a V-belt? #5
I would try paint thinner before I used brake cleaner.
Paint thinner is a less aggressive solvent and is less likely to deteriorate the rubber.
If paint thinner fails and the choice is brake cleaner of throw it away, try the brake cleaner.
I would use the pray on belt dressing instead of soap to increase the grip.
The reason I am being a cheap skate is that the new belt is $42 and I am not sure I have all the oil leaks fixed. Oil was definitely running out of the oil pressure sender but it is pretty common for these engines to leak from the crank seal. I just need to run it enough to see if it is still leaking. No sense in ruining another belt.
Chris
   / Can I clean oil off a V-belt? #7
Assuming a vertical crankshaft engine?If this is Briggs stratton engine, a lot of them loosen the crankcase bolts along the sides just from running. You might pull the engine, and tighten them to slow the flow of oil. I would look to see if it is coming from the lower shaft seal first?This might slow the flow of oil to the belt, then clean it? Jy.
24ft T/A Enclosed Cargo Trailer (A55758)
24ft T/A Enclosed...
2025 Platform Safety Basket Attachment (A55787)
2025 Platform...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
High Lift Ratcheting Off Road Utility Farm Jack (A55787)
High Lift...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
