Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #571
So many great "weapons" and no snow to fight.
Have we built up the army so much we've scared off the enemy? Hope not. :D
Currently pouring down snow here.
   / Pictures of your snow weapons #572
As of 1325, 08 Jan it's flurrying here in south central PA
   / Pictures of your snow weapons #573
About 14 inches here since last evening.
Finally got to try out the snowblower on the Massey:thumbsup:
   / Pictures of your snow weapons #574
I have seriously snagged the blade both pushing and pulling with my old massey. I have rewelded the 3pth frame twice and this year added a new blade. The lower links are very strong but I can see a lighter tractor having a problem. I believe Scraper blades are made for slow work. Snow blades have shoes and trip mechanisms and are made to be used with some speed. I attached some shoes to my new blade but still have to be careful to not go too fast.
The big issue is where the force is exerted. When pulling forward the top link is pushing on the rear diff housing. When pushing in reverse its pulling. I have seen a few pull the top link mount right off the diff axle causing substantial damage. I have also seen many lower arms bent but that is minor compared to ripping out a tip link mount.
Chris
   / Pictures of your snow weapons #575
Not a single flake here in Central Maine. I knew burning all that waste oil and old tires in the yard would pay off!
   / Pictures of your snow weapons #576
So far this year we have had a little over 2'. Most at one time was maybe 8". We currently have only 3" but its blowing 25 and 8 deg so I will leave it alone.
Chris
   / Pictures of your snow weapons #577
I made it about 10 minutes with the Honda walk behind and broke another shear pin. Those things really don't like gravel. If there was a sign of some work comming in I'd go buy the 7' rear blade at TSC. (after watching wvpolcat's video) Just going to muddle thru with the box blade and my home made pusher I guess.
   / Pictures of your snow weapons #578
Sears LT 1000 "SE" under construction but had to play in the last snowstorm.
   / Pictures of your snow weapons #579
It's funny you mention that. I have a friend who works as a foreman on a large construction company and they do condominium complex snow removal-BIG TIME stuff. They have 1 Honda tracked snowblower, like 32" wide. He said "it went through a shear pin an hour" I think was how he described it. Said he finally gave up and brought a different brand of bolt.
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
2007 CATERPILLAR 420E BACKHOE (A52707)
2007 CATERPILLAR...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
30008 (A53424)
30008 (A53424)
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
NEW AIR DRYERS (A55745)
NEW AIR DRYERS...
