Mowing How big of a disk mower?
   / How big of a disk mower? #11
A 45 hp tractor can turn a 9 ft, however, the Mfgr. specs are looking more at the weight and "Stance" of the tractor for safety's sake. We have in stock the new Enorossi 7 ft double action sickle mowers with hydraulic lift kit for $3695. My Shop Foreman has a disc mower and one of these double action mowers and the double action will make a round every time the disc mower does. Damp hay don't matter. Ken Sweet
Ken .. I have no experience with the "double action" explain that. Also when I used the sickle mowers years ago I encountered plugging in gopher mounds, problems cutting thick downed Bermuda, and sickle repair ... the old boys that used to sharpen and repair just are not out there anymore. AND if you started to early in the mornimg that heavy due about shook me to death.
   / How big of a disk mower? #12
I just found this searching around. Anyone familiar with em?
ITEMS DETAILS & MODELS PRICE US$
HayMAG
(Made in USA)
Lely Style
CCM-165- 5'5"cut Shaft Drive- 800 Lbs. 22 HP min.
(works on compact tractors with rear exterior hydraulics) CALL
CCM-205- 6'9"cut- Shaft Drive- 950 Lbs.- 30 hp minimum CALL
CCM-240- 7'10"cut -Shaft Drive- 1050 Lbs- 36 HP minimum CALL
CCM-280- 9'2"cut- Shaft Drive- 1150 Lbs- 42 HP minimum CALL
The HayMAGNUM Shaft design has 1/3 less moving parts and requires 20% less PTO HP to operate than a conventional oil bath style disc mowers. Lely style cutterbar
The HayMAGNUM Spring Steel hex drive shaft that acts as a shock absorber
Cutting units are grease filled for long life and low maintenance, elevated operation all day without starving the cutterbar for lubrication
Individual cutting heads require less down time to repair.
Safety lock in transport position
Heavy duty one piece curtain for safety and extended life
Unique Heavy duty blade disc with a simple, safe & cost effective design.
Simple blade bolts, No costly blade mounting hardware as other manufacturers.
Light weight design for use on smaller & more fuel efficient tractors. SAVES FUEL !
Powder coated paint for long life.
Replaceable skid shoes
Safety release avoids damage from objects
4 belt design for long belt life
CAT 1 & 2 hitch available on all models
MADE IN THE USA
How much do they get for a 7 ft machine? If it says CALL for price, that is usually not a good sign. Ken Sweet
   / How big of a disk mower? #13
The double action setup is where the guard bar and the section bar both move. The tolerances are close enough (15 thousandth) that you can't clog them. Ken Sweet
Ken,
I just saw a NH 451 7' on your website. I have lots of hours with one of those. Very good machine.
   / How big of a disk mower? #15
Thats CCM they advertise on here as well ... I spoke with them the other day .. the model 240 7'10" cut $5595 plus shipping $385 ... they have sold alot of these and he told me I would be very pleased. Also was very knowledgeable about the product and very much on top of hay production.
   / How big of a disk mower? #16
I have known Mark for probably 20 years. He is very knowledgable. However, his shipping is way too high. I can ship for 1/2 that and if you pay by check, I can give you a 3 % discount off the machine and the freight. Our Fort disc mowers are backed up with approx 75K in new and good used parts inventory here at my location. All used parts at 1/2 price of new. Ken Sweet
   / How big of a disk mower? #17
Here are some closeup pictures of the double action cutterbar setup. Ken Sweet
   / How big of a disk mower? #18
I would go with the double action sickle mower or the drum mower. I have ran an 8 ft disc mower with that size tractor and it is hard on the tractor.
   / How big of a disk mower? #19
Drum mowers are heaviest and sickles are lightest. Drum mowers also are the cheapest, less moving parts.
My 3011 weighs 4000 pounds and has more than enough power to run the 2 meter Krone disk mower (no conditioner) but in damp grass, there isnt enough weight on the front wheels to make it track straight, i have to countersteer untill the wheels find grip, when i correct that, it takes a bit before the wheels find grip so i'm continuously correcting it.
On hills it would be a whole different story, then it wont be just an issue, but a pain in the ***. the 5245 weighs 8000 pounds and you dont notice its there.
   / How big of a disk mower? #20
If you like Vicon 3 blade per disc design and don't like the Vicon high prices, we have the new Superior 6 head disc mower with 3 blades per rotor for $6295. Ken Sweet
I did not see them on your website ... got any pictures?
1999 MATE END DUMP TRAILER (A52472)
1999 MATE END DUMP...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
