mounting 4" hand truck tires
   / mounting 4" hand truck tires #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
I'm open for all suggestions, this thing's kickin my butt. I got it off and got a tube in it, but getting it back on is proving to be a pain.
   / mounting 4" hand truck tires #2
Does it have a 2-piece rim? Otherwise some soapy lubricant might do the trick.
I think I'm gonna make one out of wood on my bandsaw. It's a 4" molded rim. There must be a trick to it, no way can I get enough hands and screwdrivers on it, and I don't want to stick myself in the eye.
   / mounting 4" hand truck tires #4
Put a long bolt through the center hole and clamp down on it with a vise. Then you only have to keep it from spinning.
Aaron Z
Aaron Z
That sounds like a good idea, thanks. I was trying to do it with the h/t stood on it's side, but that would be better.
Edit: I put a threaded rod thru the drill press table and used 2 vice grips on the rim, that was the ticket. Then I just had to fight with the valve stem. Now I know why they get so much for a hand truck tire, because they can.
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
