Largest Garden Tractor?
   / Largest Garden Tractor? #11
At one time, you had international harvester cramming a small diesel in their 982 series of garden tractors, John Deere was putting I think a three cylinder yanmar in one of theirs, Case had the 446 model---if you put them all side by size, they are roughly cousins in terms of wheel base, tire size, etc.
Some have the opinion that the John Deere diesel garden tractor was the ultimate garden tractor that kind of grew out of these competing product lines. I forget the model number, but there are websites that specifically focus on the John Deere as the most developed extension of the garden tractor.
Then there is the Kutoba 6100/7200/etc series of diesel tractors.
To me, they are all garden tractors on steroids--not compact utility tractors, but others may have differing opinions and are welcome to say so. Once you get close to Ford 8n or the Cub Lo-Boy or the Hefty G in size, to me that's a compact utility tractor because of the weight and wheel size and not necessarily based on HP, but really the physical size of the tractor.
Others may see this differently.
   / Largest Garden Tractor? #12
A John Deere 455 is the biggest I have seen. I had a diesel engine and weighed almost 1000lb.
   / Largest Garden Tractor? #13
Powerking.
**** good tractor. Gear drive. rearend with bull gears.
Solid outfit.
   / Largest Garden Tractor? #14
The John Deere 430 diesel weighed 1170 lbs and I believe it to be the heaviest of the JD garden tractors.
Rob
Good input from everybody. A couple were brought up that had not occured to me.
   / Largest Garden Tractor? #16
A Gravely 16-G with a 16 HP motor and a mowing deck weighs 1,300#. They are tanks.
   / Largest Garden Tractor? #17
I don't think it matters much but my X749 weighs 1462 lbs with the mower deck. Add a little more for the 3pt hitch and 540 pto kit, around 1500 lbs.
My benchmark for a tractor is it has to be able to outpull my grandpa's mule.:laughing:
   / Largest Garden Tractor? #18
It does kinda bring up the question of where is the line between a garden tractor and a subcompact.
My tractor is a garden tractor when its tilling the garden. :)
   / Largest Garden Tractor? #20
i would have to say either the power king or the case 440 series. both are bullet proof designs and work realy well
just my 2 cents
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
