alternatives to hydraulic top link
   / alternatives to hydraulic top link #1
oldboyscout
ne PA
Kubota B2620
does anything exist that would work like a hydraulic top link, but without the hydraulics? I'm thinking along the lines of a bottle jack, or a ratcheting chain binder like this:
   / alternatives to hydraulic top link #3
If you dont want hydraulics, the conventinal screw style toplink is about the easiest thing manually. Okay, so it isnt fancy and doesn't ratchet, but it is the same as what you posted. A case of dont try to re-invent the wheel comes to mind.
And a bottle jack is single acting, so that wouldn't work either.
But if you are looking for something better and dont have the rear remotes, there is someting out there. The name of it slips me right now but it is a self contained hydraulic unit. Raise or lower the implement and open a little bypass valve to lengthen/shorten it. It is supposed to act like a shock absorber too. Bt someone else will probabally be along shorly with the name of it.
   / alternatives to hydraulic top link #4
Here is a link. And only 200+ posts to go through. Opinions vary.
http://www.tractorbynet.com/forums/attachments/174498-hydraulink-self-contained-air-over.html
that Hydraulink looks interesting, but I don't like the "air cushion. Sallyridesdad said he built a ratcheting top link and would use the chain binder idea instead. Looks like I have some R&D to do!
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
