Row Hippers and Cultivator
   / Row Hippers and Cultivator #61
Travis - I like your garden enthusiasm - you'll need it later!
Check the hitch pins (also called lower link pins) on your hiller. From the photo the right one (tractor left) is galled, not to mention loose at the nut. You'll be best off with a new pair torqued up right.
Jim
   / Row Hippers and Cultivator #62
TravisR
You can cultivate your rows (with hippers on) until the plants get too tall.
I grew 400lbs.of potatoes(white,red and yellow) from forty lbs. of seed.Potatoes LOVE sulfur...........add after planting.
Jim
Thanks for your concern. I checked both pins when I first got the hipper and they're fine.
Now, the pins on my grader box are a different story!:D
   / Row Hippers and Cultivator #64
Here's a link for a manual for your cultivator. Has good info on set-up and parts. It originally was meant to be a 2 row cultivator. Dearborn 13- 2 Spring Tine Cultivator - Assmbly & Operator's . I use mine similar to a chisel plow, to break up the soil after winter. Not a primary tillage tool, only on ground previously worked. I follow it with a disc, smoothing out prior to planting. You might run it through the patch you worked up with the middlebuster. Should help that out, breaking up the spots the middlebuster missed. Around here, potatoes get planted early to mid March. We're looking for seed spuds now, hoping to be able to get the ground worked to plant some a little early. We plant Yukon Gold, Kennebec (white), and Pontiac (red). This cold sure causes a fella to daydream......hmmm, some okra sounds good with that squash. You gotta plant some tomatoes, too. Think home made salsa. Gardening is a really tasty addiction. HTH. Mark.
TravisR
On top of the row after the potatoes have dirt on them?
Thanks.
Travis,
You asked how to figure row spacing.
The way my cultivator was set up was using the measurement from the rear tires mounted in their widest set. Measurement was c/c on the rear tires.Then 1/2 of that gives you the center of your tractor which is where your row is made so you straddle your row of plants.
Too keep from using a ruler, hitch your cult to tractor and stand behind it
you will be able to tell where your outside plows should go so they can plow out your tracks (locate in center of wheel).
Now on to the center for your row. The row will be in the center between your hitch arms directly below where your top link bracket is on the cult. The distance between these two plows (depending on the size of your sweeps or plow points or whatever you call them in your area, mine are about 4") will depend on what you are cultivating and what you are comfortable using not up rooting your plants (can be a big bummer). I think mine are set 14" c/c of the plow points.
The next set of tines should be set to where they will be mid way between the outer edge of your center plow point and the inner edge of your outside that is in the center of your rear wheel.
Just going from memory I think my plow points/sweeps are 4", 6", and 8".
8" being the plow that plows out the tracks and makes the middle. The 4" are the ones on each side of the plants. And the 6" of course are between the inside 2 and the outside 2.
These are called one row when cultivating but in my little mind they are only a half row when laying off the rows for the garden.
Hope this helps you some and that I didn't ramble on too much.
I think gardening was a little simpler when I used a mule and a couple different plow stocks and plow points. Been a while since I plowed with a mule.
David
I'm having a very tough time trying to get the cultivator set. I really need to get the grass off of the rows. I hooked the cultivator up to the tractor for the first time yesterday. Wasn't expecting it to be this difficult. I do realize though, once I have them in the right spot, it'll be set for good...
Anymore advice to give me?
   / Row Hippers and Cultivator #68
The deeper you plant potatoes the more you will get,hill after the plant comes up until its too tall to do.May take two or three times.
   / Row Hippers and Cultivator #69
What trouble are you having?
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2013 MAXEY TRAILER MFG UTILITY TRAILER (A53843)
2013 MAXEY TRAILER...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2015 Chevrolet Silverado 3500HD Ambulance (A52377)
2015 Chevrolet...
