RickB, et al:IS the TD95D an all metric machine?
   / RickB, et al:IS the TD95D an all metric machine? #1
Jerry/MT
Elite Member
North Idaho-The Palouse
New Holland TD95D, Ford 4610 & Kubota M4500
I've been doing some checks on my 2007 TD95D and so far every fastener I've touched is metric. As it's made in Italy I think the odds are real strong that all the fasteners are metric. Can you confirm this? I want to put a tool kit together to carry in the tractor so I don't have to run back to the shop if i need to tighten something, bleed a filter, etc.
Thanks in advance for any help.
   / RickB, et al:IS the TD95D an all metric machine? #2
RickB will provide the definitive response, but I have a TN55 manufactured in Italy and it is all metric. Well, at least I haven't discovered any non-metric fittings since 2000.
I was looking through the on-line parts catalog/diagrams at Messick's and discovered that there was a tool kit (all metric) available for the TN55.
If RickB or another expert doesn't chime in, you might try searching Messick's NH parts catalog/diagrams to see if such a tool kit is available for your model.
Steve
   / RickB, et al:IS the TD95D an all metric machine? #3
Neighbours is all metric so far, but made in Turkey not Italy. Old Fiat design if I recall correctly.
The data plate on mine says "Made in Italy".
   / RickB, et al:IS the TD95D an all metric machine? #5
It's Italian, and all metric.
   / RickB, et al:IS the TD95D an all metric machine? #7
I don't think we are talking about the same model, I must be mistaken. Theirs is the model with the spur gear reduction units on the rear end made in the old Fiat factory.
EDIT I believe the ROPS data plate on the cab says made in Italy.
Thanks guys.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
UNUSED MOWER KING ECSSCT72-72" HYD TRENCHER (A51248)
UNUSED MOWER KING...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
