What engine is in my New Holland TB110?
   / What engine is in my New Holland TB110? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I guess this is "after the fact" but I would just like to know what engine is in my tractor. When I bought the tractor, I was told by a dealer that it was the same engine that was in the Ford / New Holland 7610. Today, I was told by another dealer that it is the same engine that was in the 7740. Are either or neigher of these correct?
   / What engine is in my New Holland TB110? #2
You have 90 pto hp and 304 ci and the 7740 has 86pto hp and 304 ci. The 7610 also has 86 pto hp but 268ci. I would have to say it is the same size as the 7740. It could be a totaly different engine but the specs are the same.
Bill
   / What engine is in my New Holland TB110? #3
Here's what TractorData.com - information on all makes and models of tractors says
Manufacturer: New Holland
Fuel: diesel
Aspiration: turbocharged
Cylinders: 4
Valves: -unknown-
Bore/Stroke: -unknown-
Displacement: 304 ci [5.0 L]
Power: 110 hp [82.0 kW]
Cooling: liquid
Coolant: 13.6 qts [12.9 L]
Compression: -unknown-
Rated RPMs: -unknown-
Starter volts: 12
   / What engine is in my New Holland TB110? #4
the 7740 and 7610s used the same motor and the earlier 7610 had a smaller cubic inch motor. the tb100 is a fiat tractor and i believe it had a cat motor no for sure but i know its nothing like the 7740. the ts100 had the same motor as the 7740 and 7610s, and the 7740 and 7610s still had a ford motor
   / What engine is in my New Holland TB110? #5
The 7710 had a BSD 444T, the 7740 used the Genesis engine, the TB uses the NEF engine. The Genesis is the updated Ford /BSD design. The NEF is similar, it's a combination of a NH and Fiat (Iveco)
   / What engine is in my New Holland TB110? #6
My bad. Looks like a TB100 has a Genesis engine. Like a 7740.
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2019 GENIE GS-1930...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
