What's the Deal with Spring Steel
   / What's the Deal with Spring Steel #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Can you heat that stuff and un-spring it?
I'd like to flaten out a lock washer and make a spacer out of it.
   / What's the Deal with Spring Steel #2
You sure can.;)
The trick is putting the spring back in it!:laughing:
So I'll heat it up, whack it flat, and then braze it I guess?
   / What's the Deal with Spring Steel #4
You get it red hot, and you can kiss the spring good by. ;)
   / What's the Deal with Spring Steel #5
And you can find out that it's spring steel by ruining a drill bit on it first! Then heat it up like Shield Arc said and let it cool down - no more spring! New drill bit will now work... DAMHIKT
   / What's the Deal with Spring Steel #6
sounds like a lot of trouble to make a flatwasher:D
It's more of a spacer for a spindle bolt. f/w too wide and not thick enough. The f/w that came with it is dragging on the grease seal, this ought to keep it away from it.
..but I hear ya..
   / What's the Deal with Spring Steel #8
Too keep most of the spring strength, visegrip the opening flat and heat the other parts of the ring with a propane torch. Shine up the metal a bit first. When it colors dark blue/purple stop heating. Release after cooling. Should be near flat.
larry
   / What's the Deal with Spring Steel #9
what about taking a zipcut to the appropriate size piece of pipe? then you can get exactly the height you want.
Yeah, I thought of that too. It's becoming a moot point because with the spacers in, somethings still dragging on the other side of the bearings now. Chinese crap, nothing like having to re-work brand new stuff.
2017 Ford Taurus SEL Sedan (A48082)
2017 Ford Taurus...
2011 Honda Pilot EX SUV (A50860)
2011 Honda Pilot...
Knapheide Service Bed (A50860)
Knapheide Service...
2017 Nissan Juke SUV (A48082)
2017 Nissan Juke...
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
2020 Chevrolet Express 2500 Animal Control Cargo Van (A48081)
2020 Chevrolet...
