851 Powermaster vs tiller
   / 851 Powermaster vs tiller #1
851 roger
Wheatland, Oklahoma
Ford 851 Powermaster
I purchased a Yanmar tiller last summer from a friend that used in a horse corral.
His tractor was a 801 and the dirt was always soft.
When I hooked it up to the Powermaster and gave a try, (NO WAY)!!!!!!!!!!!!!!
It picked up the back of the tractor and pushed me around the place like a kid in a wagon. It gave me a scare at first the a good laugh (so I wouldn't wet myself).
Is there some differance in the gearing of an 851 vs 801 that would cause this???
   / 851 Powermaster vs tiller #2
what transmission does his tractor have (what model). You both have 801 "series". Yours is a 851 "model" which means you have a 5 speed.
   / 851 Powermaster vs tiller #3
When I landscaped my new house a few years ago, I bought a used Yanmar RS1200 rototiller (48" wide) to use with my 2005 Kubota B7510HST tractor. That tiller is a light weight unit designed for use in the rice fields. It really bounced around on hard, dry ground. I had to use my middle buster plow to break up the soil and then follow it with the tiller. The hydrostatic tranny is a real help with that tiller because you can just crawl along and give the tiller a chance to do its thing.
Hope this helps.
Good luck.
   / 851 Powermaster vs tiller #4
What HP is your 851?
I have a TSC 5' tiller fairly heavy duty and my Mahindra 3325 handles it just fine. My soil is kind of mixed not light or to heavy. My Mahondra is 35 HP.
Don
   / 851 Powermaster vs tiller #5
Don
his 851 is around 45 hp.. but that's not the issue..it's ground speed that is the issue.. fords have tall gears till you get to the 8spd trannies. or have aux post trannis installed.
soundguy
   / 851 Powermaster vs tiller #6
as was said.. you bothg have 801 series.. you have 851 model.
he may have had an 871 or 881 that has a 10spd powershift tranny that has a low gear. or he may have had a howard or everette post tranny that dropped his ground speed without effecting his pto speed.
fords are good plow tractors.. and unless in soft soil and lots of hp and small tiller and a 5spd.. not great tillers. go to the 8spd and yep.. good tiller machines.. etc.
soundguy
   / 851 Powermaster vs tiller #7
I had (sold it a few years back) the early 4 cylinder Ford 4000 with the Selectospeed and in 1st gear it did fine. I've read the Hundred series with the manual transmissions were pretty high geared to till with. My tiller is a Grey market 60" and does okay in sandy/loam soil. bjr
   / 851 Powermaster vs tiller #8
yep.. same as an 871 or 881 the sos.. etc.. 10spd powershift..
CATERPILLAR 336FL EXCAVATOR (A51242)
CATERPILLAR 336FL...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2020 JOHN DEERE 333G SKID STEER (A51242)
2020 JOHN DEERE...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
